sliceofpie
how to make wordpress faster
Mon Apr 08, 2013 11:22 am
hi people it seems real slow http://www.sliceofpi.net/wordpress anyone know how to make it faster?
azeam
Re: how to make wordpress faster
Mon Apr 08, 2013 2:15 pm
sliceofpie wrote:hi people it seems real slow http://www.sliceofpi.net/wordpress anyone know how to make it faster?
1. Use a fast web server, check out nginx or lighttpd instead of apache.
2. See http://www.raspberrypi.org/phpBB3/viewt ... 63&t=29885 for a couple of things you can do to speed up Wordpress. http://gtmetrix.com/ is also a good site to check the speed of the website and get recommendations for improvements.
3. Get a fast (upstream) internet connection.
4. Not an answer to your question but you could use something faster than Wordpress.
sliceofpie
Mon Apr 08, 2013 3:09 pm
couldnt get nginx to work with it
had some cache pluggins but couldnt work it correctly
Piminiuser
Mon Apr 08, 2013 9:40 pm
sliceofpie wrote:couldnt get nginx to work with it
Webserver tutorial with nginx
http://raspberrypihelp.net/tutorials/24 ... -webserver
Please stop apache first. Or you will get a port error.
mud_weed
Sat Aug 17, 2013 3:12 pm
i used Varnish with some cache plugins hosted on nginx webserver
try the tutorial given @ http://www.weedpi.com
Check my blog at www.weedpi.com
Lob0426
Sat Aug 17, 2013 4:06 pm
WP Fast Cache helps a lot and is about the easiest to setup of the cache plugins. The faster web servers help some too.
Your site would not come up for me.
You should be able to see 3.5 second page load speeds with very little trouble.
512MB version 2.0 as WordPress Server
Motorola Lapdock with Pi2B
Modded Rev 1.0 with pin headers at USB
http://rich1.dyndns.tv/
(RS)Allied ships old stock to reward its Customers for long wait!
mud_weed
Sat Aug 17, 2013 5:54 pm
I am surprised. See the stats at http://stats.pingdom.com/cm97jhu1pp23/929603. You can also take a look at http://www.webpagetest.org/result/130813_9N_RHW/ for some additional performance results.
Pingdom runs test from many parts of the world and they average about 670 ms (range from 1.5 sec to .2 secs). I see similar results from webpagetest.org site as well. You should try for your website as well to compare.
I am trying to be convinced about the ability to run a fast (under 1 second response time) web site hosted using RPI and WP.
mud_weed
Sun Aug 18, 2013 6:38 pm
Do you mind checking again for me. I had the wrong cache timeout setting at the Varnish server level causing cache misses every few minutes. its fixed now.
