ive got a basic lamp server with lighttpd. i would like a /admin page that shows the amount of free ram on the pi, etc. how would i do this? would i need to somehow run a python script on the site?
thanks
Re: System stats on a website?
Get Raspcontrol or Webmin. http://www.randrade.tk/index.php/2013/0 ... from-home/
you could try this:
http://derkev.in/rpisysinfoscript/
simply extract the zip file in your lighttpd-www-directory
My Webpage: http://derkev.in
the one i'm using here http://93.97.163.97:81/livestatus/status.php is quite good although the temp reading isn't working at the moment
http://212.159.76.122:81/serendipity/
adream: Care to share the source of your live stats?
- tonyhughes
The Server Utils section of Baked Raspberry Pi Mod will install phpsysinfo for you, which is shows a heap of detail.
I just used it to install phpsysinfo as a demo for you here:
http://www.tall.co.nz/phpsysinfo/index.php?disp=dynamic
I did note that there is no option but to install to /var/www/ so if you need it in a different directory, you will need to move it, or install it manually (just drag and drop the whole phpsysinfo dir if needed).
This will be fixed in the next release.
- tonyhughes
And the most simple way I can think of to display the free ram is this:
Create a script:then paste in:
and save it (CTRL+X)
then type:then run:
Then you can just browse to http://www.domain.com/freeram.txt to see it.
There are a million ways to improve on this, and get the output looking good, or piped into another page somewhere.
Create a script:
nano ~/freeram.sh
#! /bin/bash
RAM=$(free -m)
echo $RAM > /var/www/freeram.txt
then type:
chmod +x ~/freeram.sh
~/./freeram.sh
Here is it http://raspisimon.no-ip.org/livestatushelp.php65coupei6 wrote:adream: Care to share the source of your live stats?
Raspberry Pi Model B x 2, Raspberry Pi 2 x 2, Transcend 32GB Class 10, Transcend 16GB Class 10, Transcend 8GB Class 4, Custom 12V 1.5A (stepped down to 5.5V)
