Auto Wifi Script
Posted: Wed Feb 06, 2013 6:13 am
Hello all,
Here is a script that I wrote for my pi to connect to wifi (wpa), restart wpa_supplicant if the pi is not connect to the internet, and to add static ip adresses to the wifi driver if desired. I'm posting this in hopes that someone else finds this useful. To get the script working tweak the variables at the top of the file, and add
under the wlan section of /etc/network/interfaces, be sure to chmod 755 the script.
Anyways here is the script, I find it suites my needs perfectly, but I am open to suggestions as for ways to improve it.
post-up /path/to/scriptAnyways here is the script, I find it suites my needs perfectly, but I am open to suggestions as for ways to improve it.
#!/bin/bash
addip=( '192.168.1.250/24' '192.168.43.250/24' ) #sample leave blank for none
int='wlan0'
wpaconf='/etc/wpa_supplicant/wpa_config.conf'
loop='60' #check connectivity ever 60 seconds (20.16kB/day at 60 seconds)
function add_ip () {
for ip in "${addip[@]}"; do
ip addr add $ip dev $int
done
function remove_ip () {
ip addr del $ip dev $int
done
function start_wpa () {
wpa_supplicant -B -i $int -c $wpaconf
dhclient $int
sleep 3
add_ip
function stop_wpa () {
killall wpa_supplicant
remove_ip
status=down
# slightly inefficient I know, but it works well
function wpa_status () {
status=down
if [ "$(pgrep wpa_supplicant)" != "" ]; then
wget http://www.msftncsi.com/ncsi.txt -O /dev/null
if [ "$?" == "0" ]; then
status=up
else # try a quick dns fix
echo "nameserver 8.8.8.8" > /etc/resolv.conf
wget http://www.msftncsi.com/ncsi.txt -O /dev/null │ --follow-ftp follow FTP links from HTML documents.
if [ "$?" == "0" ]; then │ --follow-tags=LIST comma-separated list of followed HTML tags.
status=up
fi
fi
fi
pidfile=/tmp/wifi_wpa_autoconfig
#to prevent multiple instances
# this works because tmpfs (/tmp) is cleared upoun reboots
if [ -f $pidfile ]; then
echo "Already Running"
exit 1
else
touch $pidfile
fi
while [ true ]; do
wpa_status
if [ "$status" == "down" ];then
stop_wpa
start_wpa
fi
sleep $loop
done
