icearrow
Automatic RDP connection
Tue Feb 05, 2013 10:03 pm
Hello everybody, this is my first post in the Forum
As the topic subject suggest, i'm working on a thin client which is going to connect to a Windows Server 2003.
Until now I've installed rdesktop and I connect to my server via Terminal or via a simple script on my desktop like this:
#!/bin/bash
rdesktop -f myserverIP
with this method I need to start LXDE (automatically or not), then I have to run the script in order to connect to the remote session, but that's not the best way if I only need the remote session.
Looking on the internet I've found a way to avoid the use of LXDE, simply by startin X and then an istance of rdesktop redirected to the X display, It's a little bit tricky but there is no need of a Window Manager at all:
On the first shel session just write X to start the Xserver without any Desktop enviroment, then switch to a 2nd shell with Alt-Ctrl-F2 and run DISPALY=:0 rdesktop -f myserverIP (use -f in order to fill the entire screen with the remote session).
Now, as I said before, this is a little bit tricky and her is my question: Is there any way to create a script with the opening instance of X and the rdesktop command?
I've tried to write down a script but it doesn't work:
#!/bin/bash
X
DISPLAY=:0 rdesktop -f myserverIP
topguy
Re: Automatic RDP connection
Tue Feb 05, 2013 10:19 pm
You need to start X in the background and take a small pause before starting rdesktop, thats all.
X &
sleep 10
icearrow
Tue Feb 05, 2013 10:26 pm
Thanks, It's working. :D
kghunt
Tue Feb 05, 2013 10:56 pm
I used to do something similar but also used watch
X &
sleep 10
DISPLAY=:0 watch -n 1 rdesktop -f myserverIP
That will keep trying the rdp every second, good if the session times out or gets disconnected.
Viriiguy
Mon Jul 25, 2016 2:50 pm
I know this is an ANCIENT topic, but it is exactly what I need.. I think.
However, I am an idiot I guess...
Where and I supposed to put this?
X &
sleep 10
topguy
Tue Jul 26, 2016 9:46 am
I suggest putting them in a script file called for example "myrdp.sh" and test it.
#!/bin/bash
X &
sleep 10
If you want this to start automatically on boot then its another discussion.
