Devon Mafia
Re: Networking with the PI is making me feel hopless
Sun Feb 17, 2013 11:35 pm
ip routing enabled....no
<- is that a thing?? (in ip config , cmd windows box)
dasimpson
Sun Feb 17, 2013 11:39 pm
no the trace should also be 194.168.4.100
you also have the dns servers set to 192.168.4.100 192.168.8.100 when the 192 needs to be 194
because you have set a static ip address the dhcp is desabled
rurwin
Sun Feb 17, 2013 11:43 pm
If you're still able to ssh in, the IP routing setting is working fine. IP routing is something only found in XP pro, and we're not using it; we're using ICS.
Have you done that ICF setting thing? The Windows Firewall may be something else, and you want that switched on.
Please ensure the Windows Firewall is switched on, and then go through that procedure I posted earlier. In that order.
Then try the "traceroute 192.168.8.100".
Devon Mafia
Sun Feb 17, 2013 11:50 pm
kay i just did that
pi@raspberrypi ~ $ traceroute 194.168.4.100
traceroute to 194.168.4.100 (194.168.4.100), 30 hops max, 60 byte packets
 1  * * *
 2  * * *
 3  * * *
 4  * * *
 5  * * *
 6  * * *
 7  * * *
 8  * * *
 9  * * *
10  * * *
11  * * *
12  * * *
13  * * *
14  * * *
15  * * *
16  * * *
17  * * *
18  * * *
19  * * *
20  * * *
21  * * *
22  * * *
23  * * *
24  * * *
25  * * *
26  * * *
27  * * *
28  * * *
29  * * *
30  * * *
pi@raspberrypi ~ $ route
Kernel IP routing table
Destination     Gateway         Genmask         Flags Metric Ref    Use Iface
default         10.0.0.1        0.0.0.0         UG    0      0        0 eth0
10.0.0.0        *               255.255.255.0   U     0      0        0 eth0
pi@raspberrypi ~ $
Devon Mafia
Sun Feb 17, 2013 11:51 pm
now the other thing
dasimpson
Sun Feb 17, 2013 11:52 pm
now this seems that the router hase the option not to bonce information back when pinged
Devon Mafia
Sun Feb 17, 2013 11:54 pm
Under Internet Connection Firewall, clear the Protect my computer and network by limiting or preventing access to this computer from the Internet check box.
this doesnt exist, there is a blank box with windows firewall above it and a button with settings on
in here i only have 'windows firewall settings'
dasimpson
Sun Feb 17, 2013 11:56 pm
ok disable the firewall on your ethernet connection but not your wireless connection
rurwin
Sun Feb 17, 2013 11:58 pm
That's what he is trying to do.
Try this: http://kb.wisc.edu/page.php?id=2132
If that doesn't work I'll check it on Monday. Unfortunately the only other alternative is using Microsoft's KnowledgeBase article and that is even more flawed as you've already found out.
dasimpson
Mon Feb 18, 2013 12:00 am
he was trying to follow the directions you put that he cont find so i basicly told him what you ment and sorry to a tech and you dont ethern have xp in a vm lol
dasimpson
Mon Feb 18, 2013 12:02 am
have you tried loading the internet on the rpi since doing the latest changes or have you just been trying the traceroute
Devon Mafia
Mon Feb 18, 2013 12:08 am
lots of things, ive been pinging google and trying apt-get update
I cant believe them xp help files are liars!
dasimpson
Mon Feb 18, 2013 12:11 am
i just cont work out why you are having so much trouble and mine worked first time and in many different places
Devon Mafia
Mon Feb 18, 2013 12:19 am
yeah crazy, its the complications based on xp being an arse and not allowing dynamic ics ip address right?
I started with that but i had windows 7...and the internet still didnt work then!
can you think of anything piwards that could be the issue?
some internet ethernet settings of some kind??
dasimpson
Mon Feb 18, 2013 12:21 am
my netbook in on xp i use wireless for internet and ethernet for the pi with no problems lol also tried windows 7 now that is a pain
dasimpson
Mon Feb 18, 2013 12:22 am
thats why i thoght of you starting clean on the pi side and i take you thru how i did it as much as the other fella says it wont work mine works
also to anaother point i have never had probs with microsoft knoledgebase
Devon Mafia
Mon Feb 18, 2013 12:32 am
knowledge base is different to my version of xp!! if i start afresh i think it will all be the same, i got a good record of setting everthing to static, there was an ics issue, maybe its the pi settings?
dasimpson
Mon Feb 18, 2013 12:35 am
as i said i have the same ip as you on router etc and mine works so i think starting clean on the pi is best otpion that way what ever the setting that is wonr wont be any longer
dasimpson
what xp you on and servicepack
Devon Mafia
Mon Feb 18, 2013 12:44 am
xp professional service pack 3
something 2002
I hope i havnt compromised my security over all this, not that it bothers me much, might have just done it again :/
dasimpson
Mon Feb 18, 2013 12:45 am
nope your same windows version as me and service pack
Devon Mafia
Mon Feb 18, 2013 12:55 am
whaaat :/ its got to be a pi thing then
Devon Mafia
Mon Feb 18, 2013 12:57 am
i will log into my ubuntu partition, maybes that might offer something
dasimpson
Mon Feb 18, 2013 1:00 am
i would say so hence start clean on the pi
this is what i do connect pi to laptop turn laptop on and then the pi
log into windows go to connections turn ics on restart the pi when it has fully loaded test the pi and internet is there some times it takes a couple of restarts of the pi
