Thijxx
OwnCloud tutorial
Sat Jan 26, 2013 8:22 pm
Pie should be shared! So sometimes I give someone a Pi as a present, packed with Raspbmc and ready to go.
I manage them using SSH over VPN. To learn more about my way with the Pi and VPN, check my post about it;
http://www.raspberrypi.org/phpBB3/viewt ... 31#p201431
I have this network of Raspberries and want to build a cloud of raspberries. You follow? :P
After some research it became clear to me I should give OwnCloud a try. I will also try SparkleShare (http://sparkleshare.org/) in the future.
Note: OwnCloud is a webservice running on a webserver, the webserver by default uses /var/www as the directory for data storage, you probably want this potentialy large directory on your external drive. Take this: http://forum.owncloud.org/viewtopic.php?f=3&t=20#p53
Always make a backup if you care about the current configuration of your Pi and brush your teeth before you go to bed.
This tutorial is based on the Raspberry Pi version B (thanks for the extra memory!) loaded with "2012-09-18-wheezy-raspbian".
Main source of information: http://www.instructables.com/id/Raspber ... pbox-clone
Apache2 can be replaced by Nginx. May help regarding performance.
Pre-installation
First we install Apache2 & PHP5
Manual: http://www.instructables.com/id/Raspber ... hp-Apache/
Then we install OwnCloud
# Downloading: (check for the lastest version here: http://owncloud.org/changelog/)
wget http://mirrors.owncloud.org/releases/owncloud-4.5.1.tar.bz2
# Unziping
sudo tar -xjf owncloud-4.5.1.tar.bz2
# Copy to the web root
sudo cp -r owncloud /var/www
# Give the webserver permission to access the owncloud directory
sudo chown -R www-data:www-data /var/www/owncloud/
# Take it to the browser
Surf to https://IPADDRESS/owncloud where you fill in the IP address of the Pi
Follow the directions on screen and your done.
If you get a security warning saying "Your data directory and your files are probably accessible from the internet.", change Apache2 security setting in /etc/apache2/sites-available/default
Here is how: http://forum.owncloud.org/viewtopic.php ... 3042#p6394
Notes:
Great interface. Clean & light.
There is an App store for OwnCloud, awesome plug-ins like Torrent client or Webmail. (Settings > Apps)
The maximum file size of 2GB makes me cry.
There is an App for iOS, it's works fine but no auto-upload (of all your crazy holiday pics. ).
I had some minor trouble with getting SSL to work, didn't fill in commonName field of the certificate.
You can sync your phone with it, contacts, calendar and more.
It should be easy to burn down your Pi using OwnCloud on a group of clients on the same time.
I did not test transfer speed or stability.
Here your can find the latest documentation: https://github.com/owncloud/documentation.
Should add Apache2 to boot sequence in order to be always-on.
Please feel free to comment!
Mimi: Where'd you come from?
Doyle: My mom and the authorities are still trying to figure that out.
Annie
Re: OwnCloud tutorial
Sun Apr 27, 2014 10:57 pm
Thnx for the guide, it helped me alot.
Just one thing:
Check the following link for the correct version and download-link as it has changed since this guide was written: http://owncloud.org/changelog/
Thijxx
Mon Apr 28, 2014 8:03 am
Annie wrote:Thnx for the guide, it helped me alot.
Just one thing:
Thanks Annie! Made the change.
Bye the way; I don't use OwnCloud anymore because I don't like the 'does it all' approach and I use Seafile (http://seafile.com/en/home/) at the moment, a beautiful dropbox alternative.
