Install Fail Apache2
Posted: Fri Jan 18, 2013 7:29 pm
I just installed the latest Image of Raspbian “wheezy” (16.12.2012)
and also set up samba)
Then i started to install Apache 2
pi@raspberrypi ~ $ sudo apt-get install apache2
Reading package lists... Done
Building dependency tree
The following extra packages will be installed:
apache2-mpm-worker apache2-utils apache2.2-bin apache2.2-common libapr1
libaprutil1 libaprutil1-dbd-sqlite3 libaprutil1-ldap ssl-cert
Suggested packages:
apache2-doc apache2-suexec apache2-suexec-custom openssl-blacklist
apache2 apache2-mpm-worker apache2-utils apache2.2-bin apache2.2-common
libapr1 libaprutil1 libaprutil1-dbd-sqlite3 libaprutil1-ldap ssl-cert
0 upgraded, 10 newly installed, 0 to remove and 96 not upgraded.
Need to get 1,348 kB of archives.
After this operation, 4,990 kB of additional disk space will be used.
Do you want to continue [Y/n]? y
Get:1 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libapr1 armhf 1.4.6-3 [90.4 kB]
Get:2 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libaprutil1 armhf 1.4.1-3 [77.1 kB]
Get:3 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libaprutil1-dbd-sqlite3 armhf 1.4.1-3 [17.2 kB]
Get:4 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libaprutil1-ldap armhf 1.4.1-3 [16.0 kB]
Get:5 http://mirrordirector.raspbian.org/raspbian/ wheezy/main apache2.2-bin armhf 2.2.22-12 [672 kB]
Get:6 http://mirrordirector.raspbian.org/raspbian/ wheezy/main apache2 armhf 2.2.22-12 [1,432 B]
Get:7 http://mirrordirector.raspbian.org/raspbian/ wheezy/main apache2-utils armhf 2.2.22-12 [162 kB]
Get:8 http://mirrordirector.raspbian.org/raspbian/ wheezy/main apache2.2-common armhf 2.2.22-12 [291 kB]
Get:9 http://mirrordirector.raspbian.org/raspbian/ wheezy/main apache2-mpm-worker armhf 2.2.22-12 [2,244 B]
Get:10 http://mirrordirector.raspbian.org/raspbian/ wheezy/main ssl-cert all 1.0.32 [19.5 kB]
Fetched 1,348 kB in 3s (410 kB/s)
Preconfiguring packages ...
Selecting previously unselected package libapr1.
(Reading database ... 60548 files and directories currently installed.)
Unpacking libapr1 (from .../libapr1_1.4.6-3_armhf.deb) ...
Selecting previously unselected package libaprutil1.
Unpacking libaprutil1 (from .../libaprutil1_1.4.1-3_armhf.deb) ...
Selecting previously unselected package libaprutil1-dbd-sqlite3.
Unpacking libaprutil1-dbd-sqlite3 (from .../libaprutil1-dbd-sqlite3_1.4.1-3_armhf.deb) ...
Selecting previously unselected package libaprutil1-ldap.
Unpacking libaprutil1-ldap (from .../libaprutil1-ldap_1.4.1-3_armhf.deb) ...
Selecting previously unselected package apache2.2-bin.
Unpacking apache2.2-bin (from .../apache2.2-bin_2.2.22-12_armhf.deb) ...
Selecting previously unselected package apache2-utils.
Unpacking apache2-utils (from .../apache2-utils_2.2.22-12_armhf.deb) ...
Selecting previously unselected package apache2.2-common.
Unpacking apache2.2-common (from .../apache2.2-common_2.2.22-12_armhf.deb) ...
Selecting previously unselected package apache2-mpm-worker.
Unpacking apache2-mpm-worker (from .../apache2-mpm-worker_2.2.22-12_armhf.deb) ...
Unpacking apache2 (from .../apache2_2.2.22-12_armhf.deb) ...
Selecting previously unselected package ssl-cert.
Unpacking ssl-cert (from .../ssl-cert_1.0.32_all.deb) ...
Processing triggers for man-db ...
Use of uninitialized value $value in substitution (s///) at /usr/share/perl5/Debconf/Format/822.pm line 65, <$__ANONIO__> line 604.
Use of uninitialized value $item in hash element at /usr/share/perl5/Debconf/DbDriver/File.pm line 85, <$__ANONIO__> chunk 604.
Setting up libapr1 (1.4.6-3) ...
Setting up libaprutil1 (1.4.1-3) ...
Setting up libaprutil1-dbd-sqlite3 (1.4.1-3) ...
Setting up libaprutil1-ldap (1.4.1-3) ...
Setting up apache2.2-bin (2.2.22-12) ...
Setting up apache2-utils (2.2.22-12) ...
Setting up apache2.2-common (2.2.22-12) ...
Enabling site default.
Enabling module alias.
Enabling module autoindex.
Enabling module dir.
Enabling module env.
Enabling module mime.
Enabling module negotiation.
Enabling module setenvif.
Enabling module status.
Enabling module auth_basic.
Enabling module deflate.
Enabling module authz_default.
Enabling module authz_user.
Enabling module authz_groupfile.
Enabling module authn_file.
Enabling module authz_host.
Enabling module reqtimeout.
Setting up apache2-mpm-worker (2.2.22-12) ...
Segmentation fault
[....] Starting web server: apache2Segmentation fault
Action 'start' failed.
The Apache error log may have more information.
failed!
invoke-rc.d: initscript apache2, action "start" failed.
Setting up apache2 (2.2.22-12) ...
Setting up ssl-cert (1.0.32) ...
The i tryed to restart Apache service
pi@raspberrypi ~ $ sudo service apache2 restart
Segmentation fault
Action 'configtest' failed.
failed!
Does somebody know a solution
Jeff
Suggested packages:
Segmentation fault
failed!
Segmentation fault
failed!
Jeff
