brandoncheah
RaspAP WiFi Client AP Mode only 1 device can be connected
Wed Nov 04, 2020 4:50 am
Currently using Raspberry Pi Model 4B (1 GB RAM) and trying to configure it to be a hotspot and allow other raspberry pi connect to it.
I install RaspAP from this command:
curl -sL https://install.raspap.com | bash
Also followed this guide to setup WiFi Client AP Mode (http://matnet.my/blog/2020/01/__trashed/)
I can see the hotspot SSID showing up on other device, but only 1 device is able to connect at a time.
I tried to connect using my phone and laptop to the hotspot, but only the first device can connect and the second device couldn't connect to it.
If i disconnect the first device, the second device can connect to it.
I tried install RaspAP and do the same configuration on Raspberry Pi 3B+, and i can connect to the hotspot with more than 1 devices.
Anybody know what is going on with Raspberry Pi 4B that may cause only 1 device able to connect to its hotspot at a time?
