Lxw2015
network bridging
Fri Aug 28, 2020 9:20 pm
Hi, I have RPi 4 connect to a RPi3 via usb C . so rpi3 usb0 network interface shows up. on RPi 3, I set a bridge
brctl addbr br0
brctl addif br0 eth0, usb0.
ping works between RPi3 and RPi4.
when RPi reset. I expect ping still work. but I was wrong.
then I show RPi3 bridge. brctl show br0
and discovered, usb0 is not in bridge br0 anymore. brctl addif br0 usb0. then ping worked again.
I wonder how to add the usb0 automatically into br0, when usb0 is available.
thanks
Lxw2015
epoch1970
Re: network bridging
Fri Aug 28, 2020 9:41 pm
You can use systemd-networkd, as in this example.
https://www.raspberrypi.org/documentati ... bridged.md
In your case you’d need an extra file “ br0-member-usb0.network”
Dhcdpc configures the bridge, on raspios.
Lxw2015
Sat Aug 29, 2020 3:43 am
thank you so much. it worked.
