rpi 4 freezes when i plug in my lacie big5 usb3
Posted: Fri Aug 14, 2020 6:19 am
by mwatkins1234
i have a brand new rpi 4+ running rasberry pi full os 32 bit. the firmware is up to date as of april 2020. I am new to the linux world but assume i need so sort of driver. Everytime I either hot plug or boot with my lacie big 5 plugged into one of the usb 3 ports my rpi freezes and never mounts the drive. The lacie big 5 is a drive array formatted ntfs and self powered. Any help is much appreciated.
Re: rpi 4 freezes when i plug in my lacie big5 usb3
Posted: Fri Aug 14, 2020 11:29 am
by fruitoftheloom
If running Raspberry Pi Operating System you should fully update as there has been constant development:
https://www.raspberrypi.org/documentati ... pdating.md
Posted: Fri Aug 14, 2020 2:04 pm
by DougieLawson
Is there any way you could reformat that drive as EXT4? Running NTFS on Linux systems is an ugly hack.
Posted: Fri Aug 14, 2020 4:28 pm
by mwatkins1234
Formatting with ext4 didn't help. It appears it is locking up all usb ports.
Posted: Fri Aug 14, 2020 4:39 pm
by fruitoftheloom
Maybe this Lacie Big 5 is drawing power from USB ??
Also can you provide a link to the actual product ??
Posted: Fri Aug 14, 2020 5:48 pm
by pidd
Is the BIG 5's USB3 port an access port or an "expansion" port.
Posted: Fri Aug 14, 2020 9:56 pm
by mwatkins1234
Got it going. Reformatting and Updating the PI resolved the issue. Thanks for the help. I thought it had updated on the initial install but I ran through the update and that cleared it up. Here is a link to the product for those curious. I am running raid 5 with 8TB, 5.5 TB after raid and formatting. Mine is also running on USB 3. https://www.lacie.com/products/big/5big-thunderbolt-2/
