DaveInUK
is this a DoS attack?
Fri May 15, 2020 12:02 pm
I have a website which is totally password protected with .htaccess.
I assume that due to the password protection I attract a great deal of random searches/attacks.
The code below, shows part of a listing in "apache2/access.log" of one attack, which lasted for 101 attempts (thankfully all unsuccessful).
I have two questions:-
  • Why do they use the SAME search for all 101 attempts, is this a DoS?
  • I have searched Apache codes and cannot find the significance the second code "737" and therefore I don't understand why it changes to "736" and then finally, to "701" , all for the same search?
217.247.112.55 - - [15/May/2020:11:40:35 +0100] 	GET /phpmyadmin/ HTTP/1.1	 401 737
217.247.112.55 - - [15/May/2020:11:40:35 +0100] 	GET /phpmyadmin/ HTTP/1.1	 401 736
217.247.112.55 - - [15/May/2020:11:40:35 +0100] 	GET /phpmyadmin/ HTTP/1.1	 401 701
Cheers,
Dave
Cheers,
Dave
I'm feeling optimistic, but I'm sure something with go wrong :!:
Re: is this a DoS attack?
Fri May 15, 2020 3:21 pm
Not a DDos attack, just a script kiddie with a bug in their probing script.
Install fail2ban (with IIRC default settings or a small tweak to activate the "no-kiddies" jail) and you can knock those off your system in an instant.
B.Goode
Fri May 15, 2020 3:43 pm
I think you have the logic of that backwards.
ANY system exposed to the global Internet will attract "a great deal of random searches/attacks"
It is your password protection that prevents those probing connection attempts from progressing to being full scale compromise or exploitation of your system.
I wouldn't categorise this as a DoS attack - just some unsolicited rattling of door handles. Harmless in itself, but who knows what the intent is should one of those doors prove to be unsecured... ? That's when participation in a DDos attack might take place.
Fri May 15, 2020 3:56 pm
Nothing to do with your password protection or how attractive you are. And why would anyone want to DDOS you? Just a normal day on the internet.
DaveInUK
Sat May 16, 2020 1:08 pm
Thanks for the suggestion, I'm still working my way through learning how to optimize the fail2ban filters. I'm sure I'll be back soon asking more questions.
Thanks also to the others who have responded. At least I'm reassured that it's "normal" :twisted:
Cheers,
Dave
Sat May 16, 2020 4:00 pm
All you need to do is update /etc/fail2ban/jail.d/active-jails.conf
[apache-auth]
enabled = true
[apache-badbots]
enabled = true
[apache-noscript]
enabled = true
[apache-overflows]
enabled = true
[apache-nohome]
enabled = true
[apache-botsearch]
enabled = true
[apache-fakegooglebot]
enabled = true
[apache-modsecurity]
enabled = true
[apache-shellshock]
enabled = true
and it will "just work".
DaveInUK
Sun May 24, 2020 1:32 pm
[/code] and it will "just work".
Thanks for the tips.
Cheers,
Dave
bls
Contact: Twitter
Sun May 24, 2020 2:34 pm
[apache-auth]
enabled = true
[apache-badbots]
enabled = true
[apache-noscript]
enabled = true
[apache-overflows]
enabled = true
[apache-nohome]
enabled = true
[apache-botsearch]
enabled = true
enabled = true
enabled = true
[apache-shellshock]
enabled = true
Is this a "Dougie file"? I don't have active-jails.conf in my fail2ban configuration. Easy enough to make the changes in /etc/fail2ban/jail.local
Pi tools:
Easily and quickly build customized-just-for-you SD Cards: https://github.com/gitbls/sdm
Free your network from your router's DHCP/DNS:https://github.com/gitbls/ndm
Easy strongSwan VPN installer/manager: https://github.com/gitbls/pistrong
Lightweight Virtual VNC Config: https://github.com/gitbls/RPiVNCHowTo
Sun May 24, 2020 7:17 pm
Ah you have the newer version with the .local stuff.
