Cuervo
Problems installing Nextcloud. 32bit PHP environment, open_basedir
Fri Apr 17, 2020 11:23 pm
Hi.
I am installing Nextcloud, but it gives me the following error right at first start:
It seems that this Nextcloud instance is running on a 32-bit PHP environment and the open_basedir has been configured in php.ini. This will lead to problems with files over 4 GB and is highly discouraged. Please remove the open_basedir setting within your php.ini or switch to 64-bit PHP.
If I ignore the error it works fine, but I notice that it fails with some apps.
NextCloudPi is a good option, but I need to install Nextcloud as a simple additional website.
If anyone knows that it can be done thank you very much.
