Thijxx
File sharing with OSX
Tue Dec 25, 2012 3:01 pm
I never really enjoy Samba (who does?) and I do not have Windows machines but I do want easy file sharing with my Mac running OSX Lion. TimeMachine setup is included. The distribution I used this for is Raspbmc, it should work fine on Raspbian but mind the /media directory notes later on.
Updated: 20-06-2013 (ddmmyyyy ofcourse..)
  • - Added Read/Write setting
Netatalk is the file server I use to connect my Mac.
More info: http://netatalk.sourceforge.net/
Installation:
sudo apt-get update
sudo apt-get install netatalk
Configuration:
sudo /etc/init.d/netatalk stop
sudo nano /etc/netatalk/AppleVolumes.default
Now go all the way down (ctrl-v) and you see:
~/ "Home Directory"
That's where you can add an extra path. ~/ is the home directory of the current user, I've added /media to to share all my plugged in USB drives (Raspbmc only). You should add /mnt in stead of /media if you use Raspbian.
Then it looks like this:
~/ "Home Directory"
/media "Media"
/mnt "Mount"
Read/Write: Add this to the line starting with :DEFAULT:
rw
TimeMachine (thanks sonvivant!): Add the 'tm' to this line as shown here:
:DEFAULT: options:upriv,usedots,tm
Start Netatalk again with: sudo /etc/init.d/netatalk start
Make sure the user you login with from your Mac has access tot the folder you are sharing on your Pi. Start with just the default Home Directory and take it from there.
The Pi will show up in Finder on your Mac, it usually takes 10 seconds for my Pi to show up after I restart Netatalk.
When you see it in Finder, select it in the Navigation Pane and use the button "Connect As.."
If it doesn't show up, feel free to use the Connect to Server function in finder and use the IP of the Pi. (hihi, funny, the ip of the pi).
You need to use the credentials of an existing user on your Pi. I've used the default user Pi and that's working fine.
That's all folks!
ps. For 'Raspberry to Raspberry' file sharing I use NFS and that's working great.
Mimi: Where'd you come from?
Doyle: My mom and the authorities are still trying to figure that out.
adream
Re: File sharing with OSX
Mon Dec 31, 2012 2:46 am
great, thanks for this simple walkthrough much appreciated
Reason: Edited out inappropriate URL.
http://212.159.76.122:81/serendipity/
burakpi
Fri Feb 01, 2013 4:42 pm
Great tutorial. But I have a question:
I cannot write to my /media/MEDIA usb disk connected to Raspberry from my Mac. Is it about file systems? USB is FAT32.
Thijxx
Sun Feb 17, 2013 2:21 pm
burakpi wrote:Great tutorial. But I have a question:
Hi BurakPi, I might be a 'rights' issue but I always format my drives EXT4 so I cannot recreate your problem.. Try making a single (unimportant) folder completely writeable by anyone using chmod and then try to write to that folder.
cudmore
Sun Mar 03, 2013 1:18 am
Thank you so much. Just followed your instructions and now my pi is running afp, I can mount it from my osx machine.
As you say, next step is setting up a time machine backup with the pi as the server. Any pointers?
Thijxx
Sun Mar 03, 2013 4:32 pm
cudmore wrote:Thank you so much. Just followed your instructions and now my pi is running afp, I can mount it from my osx machine.
No specific pointers, didn't got to it myself just yet..
This looks like a nice & clean tutorial, this is what I will follow when I get to it: http://blog.stevenlu.com/2012/05/10/tim ... ianubuntu/
sonvivant
Sun Mar 10, 2013 2:14 am
It looks like netatalk has native Time Machine support. When I edited AppleVolumes.default I read through the file and there is an option to enable it on drives. I changed the default options line near the bottom of AppleVolumes.default to this:
Thanks, Thijxx, for the tutorial. I am now sharing files across my home network and have Time Machine access. Unfortunately the HDD that I want to use for TM is only showing about 13GB of storage when there should be almost 2TB available but I think that is a problem with some other service which I will try to figure out another time!
MSDOS4
Tue Apr 09, 2013 10:19 pm
Thanks for the tutorial! It works just fine except for one problem.
I have a 1TB usb hdd mounted on my pi and I can read/write, but mac's finder reports only 5~ GB available, which is what is left of my Raspi's sd card. I cannot write large files to the hdd or do large batches because of this. Finder will tell me there "isn't enough disk space". Do you know of any ways to fix this?
Zwerge
Sun Apr 28, 2013 11:37 am
I have exactly same problem, fails to recognize my external HD volume and instead sees SD card volume...
Thijxx
Thu May 09, 2013 8:15 am
sonvivant wrote:It looks like netatalk has native Time Machine support. When I edited AppleVolumes.default I read through the file and there is an option to enable it on drives. I changed the default options line near the bottom of AppleVolumes.default to this:
Great stuff! I'll build a TimeMachine myself!
Your HDD problem must have something to do with the format, is it EXT4?
Thijxx
Thu May 09, 2013 8:18 am
MSDOS4 wrote:Thanks for the tutorial! It works just fine except for one problem.
Hi MSDOS4,
Did you share a directory on your external drive? If the Pi shows to right amount of free space "df -h" then your Max should as well.
If not, there must be something wrong with the format of the HDD, is it EXT4?
And how do you see the free space in Finder? I can't get my Mac to do that when it comes to network shares.
MSDOS4
Thu May 09, 2013 8:45 pm
Thijxx wrote: Hi MSDOS4,
Yes, the drive is EXT4.
I made the mistake of sharing only "/media" I fixed the problem by adding my drive's name to that. Now it shows the full amount.
Finder should always show free disk space at the bottom of a window, are you sure don't have the window in extended mode?
You can see finder reporting the true free space over the network now that it's been fixed, try clicking that grey button in the corner. If that is not it, then I have no idea! :(
Thijxx
Thu May 09, 2013 9:17 pm
IMG deleted
Great that you solved it!
I had the Status Bar turned off so I didn't see the free space :mrgreen: thanks for the screenshot
oberlointment
Tue Jun 18, 2013 5:17 pm
Hi I hope that this post is still open. I have followed the steps given above and all went well. I can access my Pi and see my attached usb drives. The only issue is that I can not write to the usb drives, I can how ever write to the Pi home drive.
This is obviously a permissions issue can you give me some advice on how to rectify it.
I am running a 250gb seagate drive formatted as osx journaled, and a 16gb usb flash drive formatted at exfat.
MSDOS4
Tue Jun 18, 2013 5:49 pm
I'm not totally sure, but I think you need the partition un-journaled to be able to write.
http://forum.xbmc.org/showthread.php?tid=51626
Here's how to disable journaling:
On your Mac:
Open Disk Utility under Applications -> Utilities
Select the volume to disable journaling on.
Choose Disable Journaling from the File menu. (On later Mac OS versions you'll have to hold down the option button when you click the File menu.
oberlointment
Tue Jun 18, 2013 6:08 pm
MSDOS4 wrote:Hello,
On your Mac:
Hi Thanks so much for your quick reply. I disabled journaling but sadly I still can not write to the drive. I formatted the smaller 16gb flash drive to fat32 but could not write to this either. Any more ideas would be appreciated.
MSDOS4
Tue Jun 18, 2013 6:36 pm
Hmm... I hear you're not supposed to do this, but you might try:
sudo chmod -R 777 /media/DriveNameHere
oberlointment
Wed Jun 19, 2013 12:05 am
thank you very much that worked great! It is not showing the right file size tho, shows that I have 2gb free when I know I have 50gb any ideas?
MSDOS4
Wed Jun 19, 2013 12:27 am
Right, I had that issue too.
Do these commands:
In the document, scroll all the way down where you tell Netatalk the directory. I assume you just have it set to just "/media". You need to add the name of the drive as well, for example my external HDD is named CJ, so it looks like this:
I think that's all you need to do, just save the document and
oberlointment
Wed Jun 19, 2013 8:12 pm
thanks for your reply, I do have just
/media
so I added my external HDD so it looks like this
/media/matman_backup
but now all I get is a folder called matman_backup with nothing inside. So it would seem that it is no longer mounting the drive, could it have something to do with the name of my HDD drive?
MSDOS4
Wed Jun 19, 2013 8:31 pm
Strange, I think it might be the "_". Also, maybe keep the name no more than 8 characters long.
Don't forget to update fstab and AppleVolumes.default respectively!
Thijxx
Thu Jun 20, 2013 7:34 am
oberlointment wrote:thanks for your reply, I do have just
/media
Hi oberlointment,
To re-mount everything type
sudo mount -a
To enable writing, don't forget to add
,rw
at the end of the line starting with
:DEFAULT:
You can use long names for the shares but you need to use quotes just like the "Home Directory".
Cheers, Thijs
danb35
Thu Jun 20, 2013 10:45 am
oberlointment wrote:so I added my external HDD so it looks like this
How did you do that? If you only changed AppleVolumes.default, that won't do it. What are the contents of /etc/fstab? What's the output of running "mount"? And do you in fact have a subdirectory in /media/ called matman_backup?
oberlointment
Thu Jun 20, 2013 6:44 pm
the contents of applevolumes.default is
# The line below sets some DEFAULT, starting with Netatalk 2.1.
:DEFAULT: options:upriv,usedots,tm,rw
# By default all users have access to their home directories.
~/ "Home Directory"
/media/matman "matman"
/mnt "mount"
# End of File
and
here is the output of running mount
/dev/mmcblk0p2 on / type ext4 (rw,noatime)
proc on /proc type proc (rw)
devpts on /dev/pts type devpts (rw,noexec,nosuid,relatime,gid=5,mode=620)
/dev/mmcblk0p1 on /boot type vfat (rw,noatime)
fusectl on /sys/fs/fuse/connections type fusectl (rw)
/dev/sda1 on /media/ matman type hfsplus (rw,nosuid,nodev,uhelper=udisks)
I am doing something wrong but can not work out what. you help greatly appreciated.
BroxZaphod
Sun Oct 13, 2013 11:26 am
Thank you sir,
just what i needed! :D
Who is online
Users browsing this forum: themossinator and 13 guests
