Page 1 of 2
input / output error
Posted: Mon Dec 24, 2012 10:33 am
by jonny3010
input / output error i get this after a while of my USB hdd being mounted
i have samba,transmissions and dlna server running
Re: input / output error
Posted: Wed Dec 26, 2012 10:36 pm
by jonny3010
BUMP!
Posted: Mon Jan 28, 2013 4:24 pm
by deejayscorpion
I'm facing the same problem.
Posted: Sat Feb 02, 2013 10:21 pm
by jonny3010
when do you get this error and what drive do you have? eg Samsung and after 2 mins
are you using a powered hub?
Posted: Fri Apr 19, 2013 6:59 pm
by baldruus
I have the same problem, and I tried everything.
Now I think the problem it's on Raspbian, not HDD, because after reboot it's everything ok.
Posted: Sat Apr 20, 2013 9:32 pm
by xXAzazelXx
yep same here too :(
Posted: Sun Apr 21, 2013 3:34 am
by jojopi
I/O Error means that there was a problem reading or writing from the drive at a hardware level. That could be due to a failing hard disk, but it is more likely to be caused by a faulty or incompatible USB hub or cable, or insufficient power either to the drive, hub, or Pi.
The error is reported by the Linux kernel, so it is not the fault of Raspbian. After the error occurs, the command "dmesg" will print the kernel's log buffer. This will include details of the problem.
The most likely cause is "usb 1-1.x: USB disconnect, device number x", which means that the kernel completely lost communication with the drive, and thought it had been unplugged. Although it may detect it again shortly afterwards, the filesystem will not work properly until it has been unmounted and remounted.
Posted: Sun Apr 21, 2013 3:48 pm
by jonny3010
not had this problem for 2 months now since i did some rewiring
Posted: Tue Jul 02, 2013 11:18 am
by jamesdf
Hi there,
I'm having this problem and it's doing my head in. You said you did some re-wiring? Can you share how you did this?
J
Posted: Tue Jul 02, 2013 11:27 am
by RaTTuS
jamesdf wrote:Hi there,
J
What does
Dmesg
say after the error
how have you got the system setup?
show diagrams
show urls of all the bit's you have plugged in
Posted: Tue Jul 02, 2013 12:03 pm
by jonny3010
fixed it now i think plugging it in to a USB hub does not help. since this i have had it running for 90 days with out a problem :D
just need to do a bit of soldering to get the power from another source and not the Pi
Posted: Fri Nov 01, 2013 6:52 pm
by Magbed
Im having the same issue, works ok for a few days then it starts reporting this IO error.
Im using a USB hub with external power.
After reboot it works flawlessly again
Posted: Fri Nov 01, 2013 8:19 pm
by jonny3010
I remove mine from the Hub and had not issues. I think you need a good USB hub not a cheap one for 24/7 use. like 15 quid ones
Posted: Fri Apr 18, 2014 2:42 pm
by tribal123
Sorry for bumping this post but i have the same issue on one of mine HDD usb powered directly from AC (not from Hub)
After a while of pyLoad running the I/O error occours
Posted: Fri Apr 18, 2014 4:06 pm
by jonny3010
What HDD you using?
also what file system is it using?
Posted: Fri Apr 18, 2014 4:20 pm
by tribal123
3,5 Western Digital Elements SE - external powered
NTFS (with NTFS-3g installed)
Posted: Sat Apr 19, 2014 1:15 pm
by tribal123
However it seems that the HDD itself have issues....
Last night downloaded several files on another HDD without I/O problems
Posted: Sun May 04, 2014 1:46 pm
by RasPass
I've been having the same issue for a while, which I posted here.
It works well for a while and then I get I/O errors like you have mentioned. Not sure if it's inactivity that's causing this problem, as I set up cron to create a 5 MB file every minute to see if this would still happen, and it did, but I'm sure the hard drive is not failing as it works fine on other devices.
If you google 'raspberry pi usb external input/output errors' you'll get so many people reporting the same problem, but no solution... I don't know if getting a more expensive hub would solve the problem or just be a waste of money.
Posted: Sun May 04, 2014 2:25 pm
by tribal123
HDD having no issues with other devices means nothing.
Mine HDD too worked well on PC and on raspberry while running films etc.
But have issues while writing.
I suggest to download and run Hard Disk Sentinel (free try version) to check the Hdd.
Posted: Sun May 04, 2014 2:48 pm
by RasPass
tribal123 wrote:HDD having no issues with other devices means nothing.
It is a brand new drive that presented exactly the same problems as the one it had replaced. It is not impossible that it may have had issues out of the box, but I suspect the problems to be power related and not drive related. I just ran hdsentinel and from what I understand it didn't appear to give me any problems, saying no actions needed and health is 'excellent'.
Posted: Thu Dec 04, 2014 11:49 pm
by TheGoldyMan
Hey guys,
I have exactly the same problem as you. The only difference is that I have no HDD connected. I think the problem is that our power adapters are not capable of supplying the minimum 0.7A or 700mAh.
What do you guys think. Were you able to solve the issue by plugging your pi into a 5V 0.7A charger?
Posted: Fri Dec 05, 2014 9:25 am
by RaTTuS
you are not going to be able power a HD with .7A and the RPI
get a 2A supply
Posted: Mon May 11, 2015 1:51 am
by anilrao
I had the same issue with a USB HD. I had it configured to feed power (5V/2.1A) to the USB HD and raspberry through the same USB connection (not the micro) and found that after some time the controller chip would get hot and would throw that error. I switched the power to raspberry to the micro usb and now it is stable.
Posted: Tue Jan 19, 2016 6:15 pm
by pookeye
So I have been trying to fix this problem for months,
I have tried Raspberry B+ and Raspberry pi 2,
at the end of the day, I had a 128GB USB key that had this problem it was a PNY one, so I swapped it with another brand USB Key also 128GB and both formated at exfat,
It seems that I don't have that input output error with the new USB key, I had the input output error when I created a samba and tried to read the USB Key, I havent tried it yet with the new USB key, but will report, if it works with the new USB key...
so for now, I recommend trying a different USB device, HDD or FDD, and see if the input output goes away.
Posted: Thu Jan 21, 2016 11:11 pm
by pookeye
I can confirm switching USB Key (or storage medium that you had) seemed to have fixed it...
I thought maybe it was a power issue, so i had put the problem USB Key to a USB Hub, but i ended up getting the same issue.
so I finally just decided to change the USB Key, and it seems to be working as expected.
also I created the samba and am able to use the new USB Key with expected results.
If you are having this input/output error all the time, i recommend using a different storage medium (USB Key, HDD etc) and see if that solves your problem.
