stockton
Testing website from local network
Thu Feb 27, 2020 12:51 pm
I have a website www.stockton.co.za working fine from the internet but as I am altering it I wish to access it from my internal network but cannot.
If, from my development machine, I browse to 192.168.0.100/stockton I get a 404 496 error whereas I am sure if you try you can access it.
/var/www/html/stockton houses the website on 192.168.0.100
Re: Testing website from local network
Thu Feb 27, 2020 1:06 pm
I get a 404 Not Found when following your link. Does the file index.shtml exist?
Unreadable squiggle
stockton
Thu Feb 27, 2020 3:46 pm
Were you using http://stockton.co.za ? or http://stockton.co.za/lcars ? The shtml does exist.
Thu Feb 27, 2020 4:20 pm
Now when I try, the first of those links gives me an "Authorisation Required" page and the second link gives a "Not Found". I clicked on the link in your first post earlier.
Unreadable squiggle
stockton
Thu Feb 27, 2020 4:32 pm
That is interesting as stockton.co.za/lcars should have asked for authorization and if you clicked on the right of that screen you should have got further.
On the other hand another test has successfully got to stockton.co.za but not stockton.co.za/lcars
stockton
Thu Feb 27, 2020 5:08 pm
stockton.co.za should now work correctly.
epoch1970
Thu Feb 27, 2020 5:12 pm
2006-2020 :)
Seems to be working from the internet.
hvdwolf
Thu Feb 27, 2020 7:02 pm
Which webserver are you using? Apache or nginx?
If Apache, to which address is your server listening in virtualhost?
Only to stockton.co.za:80 or also to 192.168.0.100:80?
stockton
Fri Feb 28, 2020 7:08 am
Please tell me how I make it listen to both stockton.co.za:80(which is what it currently does) and 192.168.0.100:80?
tpyo kingg
Fri Feb 28, 2020 7:13 am
Make the one a name-based virtual host and the other an IP-based virtual host. For Apache2, if that is what you are using, the authoritative guides would be at the project web site:
http://httpd.apache.org/docs/2.4/vhosts/name-based.html
http://httpd.apache.org/docs/2.4/vhosts/ip-based.html
Give them separate configuration files.
stockton
Fri Feb 28, 2020 7:16 am
Thank you, I tried that but that just gets me to the router not the server. I set up sites-available and sites-enabled and ran a2ensite and /etc/init.d/apache2 restart
Fri Feb 28, 2020 8:32 am
What "Listen" directive is in your Apache2 config?
By default Apache2 should listen to INADDR_ANY (0.0.0.0) and not be bound to a specific interface.
https://httpd.apache.org/docs/2.4/bind.html
stockton
Fri Feb 28, 2020 8:51 am
I have altered my ports.conf from Listen 80 to Listen stockton.co.za:80 and on the next line Listen 192.168.0.100:80 and did a graceful restart but I still get to the router when attempting local connection.
Fri Feb 28, 2020 8:54 am
I have altered my ports.conf from Listen 80 to Listen stockton.co.za:80 and 192.168.0.100:80 and did a graceful restart but I still get to the router when attempting local connection.
Change it back.
Do the stockton.co.za stuff in a VirtualHost.
<VirtualHost *:80>
    ServerAdmin webmaster@stockton.co.za
    DocumentRoot /var/www/za/co/stockton # CHANGE ME
    Options +Includes -Indexes +FollowSymlinks +SymLinksIfOwnerMatch
    ServerName stockton.co.za
</VirtualHost>
stockton
Fri Feb 28, 2020 9:14 am
Dougie I fail to understand your recommendations. I have
<VirtualHost stockton.co.za:80
ServerName www.stockton.co.za
ServerAdmin alf@stockton.co.za
DocumentRoot /var/www/html/stockton
ServerAlias stockton.co.za
ErrorLog ${APACHE_LOG_DIR}/error.log
CustomLog ${APACHE_LOG_DIR}/access.log combined
Include conf-available/serve-cgi-bin.conf
</VirtualHost>
and
<VirtualHost 192.168.0.100:80>
ServerName 192.168.0.100
ServerAlias 192.168.0.100
</VirtualHost>
Please explain.
stockton
Fri Feb 28, 2020 2:04 pm
It now appears to be working for me. If I am correct in that, the solution on my machine is as follows:-
I am running Rasbian and therefore the Apache configuration follows the Debian way.
Apache needs to listen to port 80 both as an external link(DNS) & internal link(IP).
I achieved this after much help from all the above by altering /etc/apache2/ports.conf to listen to both via
and then creating a /etc/apache2/sites-available for 192.168.0.100 for I already had one for stockton.co.za
Each of their virtualhost followed the following convention <VirtualHost stockton.co.za:80> and <VirtualHost 192.168.0.100:80> and then a link from sites-enabled to both of these, followed by restarting the Apache server.
Now guys if any of the above is wrong please correct me.
All that leaves me to say is thank you one and all.
Fri Feb 28, 2020 10:06 pm
You can change the two listen directives to a single
Listen 80
