DarkElvenAngel
Looking for how-to network boot with SD card
Sat Feb 22, 2020 10:36 pm
To be clear I want to use an SD card in my pi and give it the ability to bot from the network. Even if the version of pi I have doesn't support network boot natively.
Is it possible to boot from the network with wireless communication only? I have several media players set up that I would like to just boot from the network instead of having to maintain each one?
Re: Looking for how-to network boot with SD card
Sun Feb 23, 2020 10:43 am
Unfortunately not feasible in the way you imagine:
https://www.raspberrypi.org/documentati ... des/net.md
The other way may be by using External PoE Kit so you can power on the Raspberry Pi SBC ( for models which do not support Netboot or Official PoE Hat )
https://www.amazon.co.uk/TP-LINK-TL-POE ... t-Adapter/
Though you will needs various cables to go with the kit, so at £30 it is more cost effective to buy a RPi.......
Retired disgracefully.....
DarkElvenAngel
Sun Feb 23, 2020 3:05 pm
Thanks for the reply,
I was really hoping this could work, I thought if I used the SD card there was something that could work. Maybe NFS?
I just don't know if that will work with wireless and how I would get that to work I'm thinking an initramfs stuffed with wireless stuff?
epoch1970
Sun Feb 23, 2020 4:31 pm
Initramfs is used by the kernel. So you need both on the SD. That’s not exactly net booting...
DarkElvenAngel
Sun Feb 23, 2020 6:26 pm
I'm merely speculating this is what is required. As I want to use wireless in at least one case is it possible to have the root filesystem as a NFS share?
Or is this something that will cause more issues than its going to solve?
