Danrancan
Using Terminal to scan open ports from the WAN side.
Sat Feb 08, 2020 7:07 am
Hi, I am running a webserver from my home. It is connected to my router, and my router has it's ports forwarded to the webserver on port 80 and port 443. Every router is different, so using port scan services from an external scanner is essential for me to test if my ports are available on my server.
Usually, to open up ports on my server, i use
sudo iperf3 -s -p 80
sudo iperf3 -s -p 443
, and any other ports that I want to test from my routers forwarding settings etc. etc. Then, from my raspberry pi desktop web browser, i go to https://www.whatsmyip.org/port-scanner/server/ and use their service to scan my ports from the wide area network (WAN) side, which tells me weather or not my ports are properly forwarded from my router.
My problem is that I usually ssh into my server and run it headless. So when i want to test my forwarded ports, I have to change my settings in raspi-config to boot up in desktop mode.
That being said, MY QUESTION IS:
Is there an easy way to do a wide area network portscan similar to what https://www.whatsmyip.org/port-scanner/server/ does, from the terminal using ssh on my pi? It would be much more convenient than having to log into my pi directly as a desktop user. If so, please explain and clue me in!
Thank you so much for taking the time to help answer this question. All help is appreciated!
Nerd-Tech - Exploring Technology, Computers, and Techno…
https://github.com/danrancan
dan@nerd-tech.net
https://nerd-tech.net
https://keybase.io/danran/
My Keybase Invite https://keybase.io/inv/5a35010417/
Skraaj
Re: Using Terminal to scan open ports from the WAN side.
Sat Feb 08, 2020 7:23 am
Use the following
sudo netstat -lntp
Do not skip sudo, it gives less information without it.
codedoneright.eu – newbie friendly raspberry tutorials
tpyo kingg
Sat Feb 08, 2020 9:08 am
Also, you can install lynx and go to a service like https://canyouseeme.org/ and check one port at a time.
If you have a machine outside your network you can do a more detailed scan using nmap.
Danrancan
Sun Feb 09, 2020 2:39 am
Use the following
sudo netstat -lntp
Thank you much good sir! I will try this when I get home!
dan@nerd-tech.net
Danrancan
dan@nerd-tech.net
