Help with setting up VPN please
Posted: Sat Sep 28, 2019 3:12 pm
by trentend
Hi I have a Pi4 with the latest Raspian Buster working really nicely,
I also have a subscription to Private Internet Access for VPN traffic.
But i am finding it hard to understand how I get my lovely new Pi to connect to the service.
I would like to use the wired Ethernet as the connection.
I have seen walkthroughs but they do look a little daunting.
Is there one i should be following?
Or is there a more simple client and VPN service?
Thanks in advance
Re: Help with setting up VPN please
Posted: Wed Oct 16, 2019 4:10 am
by maverik0106
PiVPN is the easiest by far to use, but if you’re using it as a client then use OpenVPN, make sure you have the security files from your VPN provider .crt and .key files to be used by OpenVPN.
This should give you a general idea, it’s pretty reliable and safe.
Good luck
Posted: Mon Nov 04, 2019 12:30 pm
by GregoryC
Hmm. Have some problems with installation too. In my case, I installed another VPN. I found an article about the best VPN for Chromebook https://webguidevpn.com/device/best-vpn-for-chromebook/
