adanchenko
How to pass public ip from wifi to eth0? Bridge mode
Fri Sep 13, 2019 2:36 pm
Dear Forum,
Please explain how to pass public ip (without nat) from wifi to ethernet?
I have an open wifi network with good speed nearby which I want to use to increase speed and load balance my own internet.
When setting RasPi as wifi bridge, it increases the speed but I can't open any webpage. Is it a double NAT problem?
I was not able to find any good guide about this, please help.
Thank you!
epoch1970
Re: How to pass public ip from wifi to eth0? Bridge mode
Fri Sep 13, 2019 4:10 pm
When you connect to the hotspot, your WiFi adapter is in STA (client) mode.
It is not possible to bridge a STA. You can only route with it.
You can bridge a WiFi interface in AP mode only.
adanchenko
Fri Sep 13, 2019 4:28 pm
I'm not a network professional, so to me it's the same :))) I just need to understand how to do that:
Wifi Internet <--> several Raspberry Pi <--> load balancing router <--> main router with the main Internet.
epoch1970
Fri Sep 13, 2019 5:17 pm
Start with one Pi and the ISP box.
Set the Pi as a router between its wifi client interface and its ethernet interface.
Configure ethernet on the Pi and the ISP box so that the load balancer is happy. Load balancing is a can of worms, follow the user manual precisely.
Your wifi link probably shows poor latency compared to the ISP link, the LB may balance less than you expect.
