follow the
https://projects.raspberrypi.org/en/pr ... -wordpress
setup a wordpress web, on Pi 3.
worked fine on 1 subnet. 10.79.97.31 is Pi's IP address. in same subnet, on anther PC. I could browse the Web on my Pi by enter 10.79.97.31
then I moved my Pi 3 to another network. and my Pi 's IP address is 192.168.0.10.
in this subnet on a PC, I browse 192.168.0.10
I expect the web on my Pi shows up. but it didn't.
I also tried on my Pi's browser, enter http://localhost also could not see my Web.
anyone have idea why not work?
thanks
Woo
Re: wordpress host
The first problem to address is your site not working when you access it as local host from your Pi.
Run these commands on your Pi. First, is Apache running?
If not, try restarting it
If this fails report the results of
sudo systemctl status apache2
sudo systemctl start apache2
sudo journal to -xe
Re: wordpress host
Another possibility is that you had set up the firewall to restrict access to port 80 on the 10.79.97.xx range only
This can be checked with
sudo ufw status verbose
Re: wordpress host
@Andyroo: No, ufw does not block ports on local host in my experience, so this doesn’t account for what the OP is seeing.
Re: wordpress host
I've never tried it to be honestnigelbartlett1 wrote: ↑Sat Sep 07, 2019 5:00 pm@Andyroo: No, ufw does not block ports on local host in my experience, so this doesn’t account for what the OP is seeing.
edit: So i did
Re: wordpress host
This could be the Wordpress installation using the old IP address (hard coded in some tables) and not the new one. Maybe check that first?
Re: wordpress host
Normally that gives some text out - often just missing the CSS and pictures.
If this is the case then there are a few addins / PHP scripts that will sort the database out.
Re: wordpress host
thanks for all you guys reply. I'll try your ideas, and get back to you.
Re: wordpress host
on Pi 3, browse localhost works. wordpress web page displayed. Maybe my first experiment messed up.
today I tried follow the instructions https://projects.raspberrypi.org/en/pr ... -wordpress install wordpress on Pi 4. failed at this step. any one have same issue? how to solved it?
pi@raspberrypi:/var/www/html $ sudo apt-get install mysql-server php-mysql -y
Reading package lists... Done
Building dependency tree
Package mysql-server is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
However the following packages replace it:
mariadb-server-10.0
E: Package 'mysql-server' has no install
mariadb-server-10.0
Re: wordpress host
Its a bit rough around the edges but for Buster https://www.raspberrypi.org/forums/view ... 1&t=249882 will get you up and running.
I've not got a Pi handy at the mo to finish the work (see my last post here) but you may not need those modules.
