charleslinquist
telnet to serial
Wed Sep 04, 2019 8:08 pm
I need a program that will run in a Raspberry that contacts a remote telnet server via name or ip and port, and after it connects, transfer that connection to serial0 so I can use an RS-232 connection from then on
All the similar programs I have found make the Raspberry the telnet host, and remote devices connect to it and use the Raspberry's serial port..
I need the reverse. The Raspberry needs to be the telnet client, which then connects to a specific host.
I have tried to write such a program in Python, but it does not work properly.
Andyroo
Re: telnet to serial
Wed Sep 04, 2019 8:16 pm
How about using the telnet package?
sudo apt install telnet
Manual is https://linux.die.net/man/1/telnet
or installed locally and accessible with:
man telnet
trejan
Wed Sep 04, 2019 10:08 pm
socat will do it. You need to look up the exact set of options to do it though. It'll be something like
socat TCP:192.168.1.2:1234 FILE:/dev/ttyAMA0,b115200,raw,echo=0,min=0
charleslinquist
Thu Sep 05, 2019 12:15 am
When I try
socat - TCP:35.160.169.47:23 /dev/serial0,b115200
I get the response "exactly 2 addresses required, (there are 4)
I can't follow the examples well enough to get this to work.
charleslinquist
Thu Sep 05, 2019 12:31 am
Doing better.
I'm getting some output with
socat TCP:35.160.169.47:23 FILE:/dev/serial0,b115200
Now I just have to fine-tune the parameters.
HermannSW
Thu Sep 05, 2019 9:27 am
Perhaps not what you want, but you can connect to Raspberry serial via USB2TTY:
https://www.raspberrypi.org/forums/view ... 3&t=156541
You can then use minicom or screen tools to login to Raspberry and "telnet" on Raspberry to connect to target.
I learned that it is important to get 5V from USB, but use USB2TTY with 3.3V setting in addtion for serial:
That was first attempt, not good because of 5V to serial:
⇨https://stamm-wilbrandt.de/en/Raspberry_camera.html
https://stamm-wilbrandt.de/github_repo_i420toh264
https://github.com/Hermann-SW/fork-raspiraw
https://twitter.com/HermannSW
charleslinquist
Thu Sep 05, 2019 2:39 pm
Thanks for your reply. Your approach won't work for me. I have an unusual application. I need to essentially make a unlimited length RS-232 connection. I have RS-232 devices on each end that cannot deal with any extraneous characters. The connection needs to be "self-healing", that is when the connection is broken, it must be seamlessly re-established without user intervention. I believe I can achieve that with socat.
blimpyway
Fri Sep 06, 2019 8:48 pm
Despite this is an PI forum. I had good experience using ESP8266 with esp-link firmware to get a TCP to serial connection..
https://github.com/jeelabs/esp-link`
PS however it is a port listener it doesn't actively open sockets to remote servers.
charleslinquist
Fri Sep 06, 2019 9:37 pm
I am successfully running SER2NET in a Raspberry (Raspberry #1). That works great for connecting the Raspberry's serial port to the net. That Raspberry has a static ip. I need to use another Raspberry (#2) to automatically telnet to Raspberry #1 - in effect, to connect their serial ports together. The network connection between #1 and #2 can easily "break" and I need it to re-establish connection after an interruption with no user intervention. I realize that data will be lost during the disconnect, but that is OK. I don't have to deal with logins and passwords because the Raspberry's are both running VPN software.
