ejolson
Gigabit Switch for Pi 4
Sun Aug 25, 2019 3:27 pm
As described in this post, see also here, my Pi 4B will not connect to a Rosewill RC-416 8-port Gigabit Green Switch.
Nobody has suggested a solution nor have I found one myself. Therefore, I'm considering the following two options:
  • Get a different switch.
  • Get a different pi-like SBC.
There is no point in trying to discuss the second option on this forum.
With regards to a different switch, does anyone know whether the TP-LINK TL-SG108 Unmanaged 10/100/1000Mbps 8-Port Gigabit Desktop Switch described here works with the Pi 4B?
Could anyone recommend an 8-port switch known to work with the 4B?
DirkS
Re: Gigabit Switch for Pi 4
Sun Aug 25, 2019 4:04 pm
I got that TPLink switch off Amazon 2 weeks ago. I have 2 4Bs and my router connected to it and it seems to be working fine.
Haven't done any in-depth tests though
thagrol
Sun Aug 25, 2019 4:05 pm
There is a third option: try another cable ;)
That said, I'm using a Tenda SG108 (https://tendacn.com/uk/product/SG108.html) without any problems with a variety of Pi including a 4B.
This space unintentionally left blank.
ejolson
Sun Aug 25, 2019 4:16 pm
I've tried four different cables, all of which work to connect the same switch at gigabit speeds to other computers. I suppose there could be a mechanical irregularity in the RJ45 socket that prevents all the wires from connecting.
For now I placed an older 100 Mbit switch between the 4B and the gigabit switch, which works but at the lower speed.
ejolson
Sun Aug 25, 2019 4:17 pm
That's good to know. Unless something turns up to fix the compatibility problems with the switch I have, I'll likely get one. It's interesting that the Tenda and the TP-LINK both have the same SG108 model number.
Could the Pi be broken?
drgeoff
Sun Aug 25, 2019 4:21 pm
I've used a D-LInk G0-SW-8G with a RPi4B.
graysky
Sun Aug 25, 2019 5:28 pm
Cisco SG100-16 works.
ejolson
Sun Aug 25, 2019 5:45 pm
That's another good data point. I'm starting to suspect the Pi 4B itself is the problem rather than the Rosewill switch. I'll have more information soon.
Sun Aug 25, 2019 6:33 pm
Netgear GS108 switch here with a cheap 3m/10ft cable from Poundworld (before they closed down here). Runs fine at 1Gb on my Pi 4B/4GB
pcmanbob
Mon Aug 26, 2019 7:15 am
I have a Netgear GS116 & GS308 and my pi4 works with both of them , using various networking cables, most of which I have made myself, lengths vary from 6" to 20ft , the longer being a hard wired LAN socket in another room.
LTolledo
Mon Aug 26, 2019 10:45 am
Am using Elecom EHC-G08PA2-B, with flat CAT6 cables for GbE equipped RPis/SBCs and flat CAT5e for 100MBbps equipped RPis/SBCs. been using for more than 6 months
started setting up RPi4B-4G yesterday...with a freshly installed Raspbian Buster with full Desktop.... connected properly to the GbE switch....
but not with Raspbian Stretch updated to Buster (cloned and updated/upgraded on RPi3B+, then microSD transferred to RPi4B, no LAN & no WiFi problem)
Some people be like:
ejolson
Wed Aug 28, 2019 11:09 pm
I have now tried that 4B which was not connecting to the Rosewill RC-416 on a different gigabit switch. It connects to a D-Link DGS-1248T no problems and I have verified gigabit speeds using iperf3. Hurray!
I'm actually a bit surprised: The RC-416 worked with all other computers I've tried and the 4B seems to work with all other switches. I wonder what the incompatibility is and whether there are other switches with similar problems. For now, I'm looking to get a different switch. Thanks for all the recommendations of gigabit switches that do work with the Raspberry Pi 4B--that will be useful to avoid any further problems!
ejolson
Fri Aug 30, 2019 6:18 am
Woohoo! The TP-LINK TL-SG108 Unmanaged 10/100/1000Mbps 8-Port Gigabit Desktop Switch is now on order. If all goes well, I'll be back to my file-server experiment soon.
azjp
Sun Sep 01, 2019 5:32 am
My golden olde (2014) Trendnet TEG-S80g works.
ejolson
Sat Sep 07, 2019 2:18 am
I have now tried the TP-LINK TL-SG108. Reported speeds with iperf3 are around 930 Mbits/sec, which seems quite promising. It's still a mystery to me what the incompatibility was with the Rosewill RC-416, because that switch has worked fine with every other computer.
At any rate, I was able to get the new switch at what I feel was a reasonable price and the performance seems good. Again thanks to everyone for mentioning which switches work.
