pumpkinpi
SOLVED: Can't see minidlna server through RPi access point
Mon Jun 24, 2019 2:16 am
I have a raspberry pi running a minidlna server on my hardwired LAN. I can see that server from VLC on computers hardwired into that LAN.
I have a couple raspberry pi's acting as wireless access points. I can't seem to see my minidlna server using VLC on my phone which is connected to the wireless access points. I suspect there is some kind of broadcast that does not pass through the access point backwards but I have no idea what to look for. Something related to that port 8200 on the server.
Just fishing here for some ideas on what to research.
This is my /etc/hostapd/hostapd.conf file on my access point:
interface=wlan0
driver=nl80211
ssid=MYSSID
hw_mode=g
channel=7
wmm_enabled=0
macaddr_acl=0
auth_algs=1
ignore_broadcast_ssid=0
wpa=2
wpa_passphrase=PASSWORD
wpa_key_mgmt=WPA-PSK
wpa_pairwise=TKIP
rsn_pairwise=CCMP
This is my /etc/dnsmasq.conf file on my access point:
dhcp-mac=set:client_is_a_pi,B8:27:EB:*:*:*
dhcp-reply-delay=tag:client_is_a_pi,2
interface=wlan0
domain-needed
bogus-priv
dhcp-range=192.168.6.2,192.168.6.100,12h
This is my /etc/dhcpcd.conf file on my access point:
hostname
clientid
persistent
option rapid_commit
option domain_name_servers, domain_name, domain_search, host_name
option classless_static_routes
option ntp_servers
option interface_mtu
require dhcp_server_identifier
slaac private
interface wlan0
static ip_address=192.168.6.1/24
static routers=192.168.6.1
static domain_name_servers=192.168.2.82
I don't have much in iptables on my access points:
sudo iptables --list
Chain INPUT (policy ACCEPT)
target     prot opt source               destination
Chain FORWARD (policy ACCEPT)
ACCEPT     all  --  anywhere             anywhere             state RELATED,ESTABLISHED
Chain OUTPUT (policy ACCEPT)
This is my /etc/minidlna.conf file (uncommented lines) on my minidlna server:
user=minidlna
media_dir=V,/home/pi/drive1/Movies
media_dir=P,/home/pi/drive1/Photos
media_dir=V,/home/pi/drive1/Videos
media_dir=A,/home/pi/Media
db_dir=/home/pi/PiDrive/minidlna
log_dir=/home/pi/PiDrive/minidlna
port=8200
friendly_name=PiHome
serial=681019810597110
inotify=yes
album_art_names=Cover.jpg/cover.jpg/AlbumArtSmall.jpg/albumartsmall.jpg
album_art_names=AlbumArt.jpg/albumart.jpg/Album.jpg/album.jpg
album_art_names=Folder.jpg/folder.jpg/Thumb.jpg/thumb.jpg
notify_interval=895
Any direction appreciated.
PPi.
Andresen
Re: Can't see minidlna server through RPi access point
Tue Jun 25, 2019 4:36 pm
Can you share the IPs for
  • the minidlna computer
  • the access point (both eth0 and wlan0)
  • a mobile device using the access point
Regards,
Andresen
pumpkinpi
Tue Jun 25, 2019 7:45 pm
Ok. Good question.
The minidlna computer is:
ifconfig
eth0      Link encap:Ethernet  HWaddr b8:27:eb:9a:f7:a5
          inet addr:192.168.2.103  Bcast:192.168.2.255  Mask:255.255.255.0
The access point is:
ifconfig
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 192.168.2.149  netmask 255.255.255.0  broadcast 192.168.2.255
wlan0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 192.168.6.1  netmask 255.255.255.0  broadcast 192.168.6.255
All the mobile devices on the access point are between 192.168.2.2 and something like 192.168.2.100.
Does this help?
Thanks,
PPi
Andyroo
Tue Jun 25, 2019 8:00 pm
There are a few notes from 2013 :o that show minidlna had a bug over multiple subnets but I doubt your version is that old.
Others note that it’s multicast routing that’s the issue and this post https://www.raspberrypi.org/forums/view ... ?p=1414184 has a possible fix...
pumpkinpi
Wed Jun 26, 2019 2:05 am
No, my version is not too old. Is there something better than minidlna I could use? Basically, I just have a bunch of audio and video files on a raspberry pi server and I want to dish them out to mobile VLC clients on the network. I am not married to this solution of using minidlna.
I am not clear on what computer I would issue this command and I am also not confident that the address written there is correct:
sudo ip route add 224.0.0.0/4 dev wlan0
I would guess I do it on my access point.
I tried this, FYI:
route -n
Kernel IP routing table
Destination     Gateway         Genmask         Flags Metric Ref    Use Iface
0.0.0.0         192.168.2.1     0.0.0.0         UG    203    0        0 eth0
0.0.0.0         192.168.6.1     0.0.0.0         UG    302    0        0 wlan0
192.168.2.0     0.0.0.0         255.255.255.0   U     203    0        0 eth0
192.168.6.0     0.0.0.0         255.255.255.0   U     302    0        0 wlan0
Andresen
Wed Jun 26, 2019 2:17 pm
PPi
Can you verify the IPs on the devices connecting to the access point? - I've not tried to recreate your setup, but my intuition expected to see something in the 192.168.6.2-192.168.6.100 range on the mobile device.
Did you follow any guides to setup the access point - and if so: can you share the link?
Regards,
Andresen
pumpkinpi
Wed Jun 26, 2019 2:52 pm
Crud. My bad. I mistyped. Your intuition is correct. Mobile devices are in .6.2 to .6.100 range.
I followed a guide I found years ago. I will try to dig it up later. The APs are running latest Stretch version and fully updated.
Andresen
Wed Jun 26, 2019 3:08 pm
Thx .
If you have a spare SD-card, could you then try to bridge the wired and the wireless network - as from:
https://www.raspberrypi.org/documentati ... et-sharing
on one of the access points?
Regards,
Andresen
pumpkinpi
Wed Jun 26, 2019 8:21 pm
Oh! That looks exactly like what I need to do. Will try it out later tonight and report back. Thanks!
Andresen
Wed Jun 26, 2019 8:33 pm
I'm pretty sure, the issue is that the broadcasts from the minidlna on 192.168.2.Y/24 never makes it to the wireless clients on 192.168.6.X/24 .. so your suspicion was right -- bridging the interfaces sounds like a much better way .. and turn the Pi into an actual Access Point and not NAT Router .. ;-)
Regards,
Andresen
pumpkinpi
Thu Jun 27, 2019 2:48 am
Boom. It works!
Thanks for the help Andresen.
Now I know about bridges.
PPi
