I am running a Raspberry Pi 3 B+ (dietpi).
I installed piVPN using these instructions (https://www.ostechnix.com/pivpn-simples ... pberry-pi/), but with the inbuilt dietpi installer.
I can connect successfully to the VPN using my phone and computer, however I have no LAN or internet access. I cannot even access the pi itself using SSH.
I have searched for a number of solutions and tried them, but I am still having no success.
This is my pivpn debug:
::: Generating Debug Output
:::: PiVPN debug ::::
:::: Latest commit ::::
fatal: Not a git repository: '/etc/.pivpn/.git'
:::: Installation settings ::::
/etc/pivpn/DET_PLATFORM -> Raspbian
/etc/pivpn/INSTALL_PORT -> 1194
/etc/pivpn/INSTALL_PROTO -> udp
/etc/pivpn/INSTALL_USER -> dietpi
/etc/pivpn/NO_UFW -> 1
/etc/pivpn/pivpnINTERFACE -> eth0
/etc/pivpn/TWO_POINT_FOUR ->
:::: setupVars file shown below ::::
pivpnUser=dietpi
UNATTUPG=unattended-upgrades
pivpnInterface=eth0
IPv4dns=192.168.1.1
IPv4addr=192.168.1.124
IPv4gw=192.168.1.1
pivpnProto=udp
PORT=1194
ENCRYPT=256
APPLY_TWO_POINT_FOUR=true
DOWNLOAD_DH_PARAM=false
PUBLICDNS=REMOTE
OVPNDNS1=8.8.8.8
OVPNDNS2=8.8.4.4
:::: Server configuration shown below ::::
dev tun
proto udp
port 1194
ca /etc/openvpn/easy-rsa/pki/ca.crt
cert /etc/openvpn/easy-rsa/pki/issued/server_OMoH02HZddW3Pe8J.crt
key /etc/openvpn/easy-rsa/pki/private/server_OMoH02HZddW3Pe8J.key
dh none
topology subnet
server 10.8.0.0 255.255.255.0
# Set your primary domain name server address for clients
push "dhcp-option DNS 8.8.8.8"
push "dhcp-option DNS 8.8.4.4"
# Prevent DNS leaks on Windows
push "block-outside-dns"
# Override the Client default gateway by using 0.0.0.0/1 and
# 128.0.0.0/1 rather than 0.0.0.0/0. This has the benefit of
# overriding but not wiping out the original default gateway.
push "redirect-gateway def1"
client-to-client
keepalive 1800 3600
remote-cert-tls client
tls-version-min 1.2
tls-crypt /etc/openvpn/easy-rsa/pki/ta.key
cipher AES-256-CBC
auth SHA256
user nobody
group nogroup
persist-key
persist-tun
crl-verify /etc/openvpn/crl.pem
status /var/log/openvpn-status.log 20
status-version 3
syslog
verb 3
#DuplicateCNs allow access control on a less-granular, per user basis.
#Remove # if you will manage access by user instead of device.
#duplicate-cn
# Generated for use by PiVPN.io
push "route 192.168.1.0 255.255.255.0"
:::: Client template file shown below ::::
client
dev tun
proto udp
remote REMOTE 1194
resolv-retry infinite
nobind
persist-key
persist-tun
remote-cert-tls server
tls-version-min 1.2
verify-x509-name server_OMoH02HZddW3Pe8J name
cipher AES-256-CBC
auth SHA256
auth-nocache
verb 3
:::: Recursive list of files in ::::
::: /etc/openvpn/easy-rsa/pki shows below :::
/etc/openvpn/easy-rsa/pki/:
ca.crt
crl.pem
Default.txt
ecparams
extensions.temp
index.txt
index.txt.attr
index.txt.attr.old
index.txt.old
issued
kris.ovpn
openssl-easyrsa.cnf
private
renewed
revoked
safessl-easyrsa.cnf
serial
serial.old
ta.key
/etc/openvpn/easy-rsa/pki/ecparams:
prime256v1.pem
/etc/openvpn/easy-rsa/pki/issued:
kris.crt
/etc/openvpn/easy-rsa/pki/private:
ca.key
kris.key
/etc/openvpn/easy-rsa/pki/renewed:
private_by_serial
reqs_by_serial
/etc/openvpn/easy-rsa/pki/renewed/private_by_serial:
/etc/openvpn/easy-rsa/pki/renewed/reqs_by_serial:
/etc/openvpn/easy-rsa/pki/revoked:
private_by_serial
reqs_by_serial
/etc/openvpn/easy-rsa/pki/revoked/private_by_serial:
/etc/openvpn/easy-rsa/pki/revoked/reqs_by_serial:
:::: Self check ::::
:: [OK] IP forwarding is enabled
:: [OK] Iptables MASQUERADE rule set
:: [OK] OpenVPN is running
:: [OK] OpenVPN is enabled (it will automatically start on reboot)
:: [OK] OpenVPN is listening on port 1194/udp
:::: Snippet of the server log ::::
May 22 21:52:46 DietPi ovpn-server[298]: 118.21.85.331:2081 ++ Certificate has E KU (str) TLS Web Client Authentication, expects TLS Web Client Authentication
May 22 21:52:46 DietPi ovpn-server[298]: 118.21.85.331:2081 VERIFY EKU OK
May 22 21:52:46 DietPi ovpn-server[298]: 118.21.85.331:2081 VERIFY OK: depth=0, CN=kris
May 22 21:52:46 DietPi ovpn-server[298]: 118.21.85.331:2081 peer info: IV_GUI_VE R=OC30Android
May 22 21:52:46 DietPi ovpn-server[298]: 118.21.85.331:2081 peer info: IV_VER=3. 2
May 22 21:52:46 DietPi ovpn-server[298]: 118.21.85.331:2081 peer info: IV_PLAT=a ndroid
May 22 21:52:46 DietPi ovpn-server[298]: 118.21.85.331:2081 peer info: IV_NCP=2
May 22 21:52:46 DietPi ovpn-server[298]: 118.21.85.331:2081 peer info: IV_TCPNL= 1
May 22 21:52:46 DietPi ovpn-server[298]: 118.21.85.331:2081 peer info: IV_PROTO= 2
May 22 21:52:46 DietPi ovpn-server[298]: 118.21.85.331:2081 peer info: IV_AUTO_S ESS=1
May 22 21:52:46 DietPi ovpn-server[298]: 118.21.85.331:2081 Control Channel: TLS v1.2, cipher TLSv1/SSLv3 ECDHE-ECDSA-AES256-GCM-SHA384
May 22 21:52:46 DietPi ovpn-server[298]: 118.21.85.331:2081 [kris] Peer Connecti on Initiated with [AF_INET]118.21.85.331:2081
May 22 21:52:46 DietPi ovpn-server[298]: MULTI: new connection by client 'kris' will cause previous active sessions by this client to be dropped. Remember to u se the --duplicate-cn option if you want multiple clients using the same certifi cate or username to concurrently connect.
May 22 21:52:46 DietPi ovpn-server[298]: MULTI_sva: pool returned IPv4=10.8.0.2, IPv6=(Not enabled)
May 22 21:52:46 DietPi ovpn-server[298]: MULTI: Learn: 10.8.0.2 -> kris/120.22.8 5.233:2081
May 22 21:52:46 DietPi ovpn-server[298]: MULTI: primary virtual IP for kris/120. 22.85.233:2081: 10.8.0.2
May 22 21:52:46 DietPi ovpn-server[298]: kris/118.21.85.331:2081 PUSH: Received control message: 'PUSH_REQUEST'
May 22 21:52:46 DietPi ovpn-server[298]: kris/118.21.85.331:2081 SENT CONTROL [k ris]: 'PUSH_REPLY,dhcp-option DNS 8.8.8.8,dhcp-option DNS 8.8.4.4,block-outside- dns,redirect-gateway def1,route 192.168.1.0 255.255.255.0,route-gateway 10.8.0.1 ,topology subnet,ping 1800,ping-restart 3600,ifconfig 10.8.0.2 255.255.255.0,pee r-id 1,cipher AES-256-GCM' (status=1)
May 22 21:52:46 DietPi ovpn-server[298]: kris/118.21.85.331:2081 Data Channel En crypt: Cipher 'AES-256-GCM' initialized with 256 bit key
May 22 21:52:46 DietPi ovpn-server[298]: kris/118.21.85.331:2081 Data Channel De crypt: Cipher 'AES-256-GCM' initialized with 256 bit key
:::: Debug complete ::::
::: Debug output completed above.
::: Copy saved to /tmp/debug.txt
