CloudOne
I can't see any client in dnsmasq.leases
Wed May 22, 2019 5:55 pm
I'm using a Rpi 3 with a bridge using hostapd, dnsmasq and bridge-utils. I would like to get the IP from /var/lib/misc/dnsmasq.leases but the problem is that it shows nothing. The hotspot works fine, I can connect to the Internet via the actual rpi and an external device like a mobile phone.
These are my conf files:
/etc/dhcpcd.conf
interface wlan0
    static ip_address=192.168.0.10/24
    denyinterfaces eth0
    denyinterfaces wlan0
/etc/network/interfaces
source-directory /etc/network/interfaces.d
    auto br0
    iface br0 inet manual
    bridge_ports eth0 wlan0
/etc/dnsmasq.conf
  interface=wlan0
    dhcp-range=192.168.4.2,192.168.4.20,255.255.255.0,24h
/etc/hostapd/hostapd.conf
interface=wlan0
    bridge=br0
    hw_mode=g
    channel=7
    wmm_enabled=0
    macaddr_acl=0
    auth_algs=1
    ignore_broadcast_ssid=0
    wpa=2
    wpa_key_mgmt=WPA-PSK
    wpa_pairwise=TKIP
    rsn_pairwise=CCMP
    ssid=node1
    wpa_passphrase=mypassword
$ brctl show
bridge name	bridge id STP enabled	interfaces
    br0	8000.b827eb8691b6	    no		                eth0
	        	        		wlan0
I also use the "Network settings" of Linux Mint 19 and it perfectly creates a hotspot where the clients are well-displayed on dnsmasq.leases. The difference is that in Linux Mint I don't have a bridge but the rpi has.
epoch1970
Re: I can't see any client in dnsmasq.leases
Wed May 22, 2019 6:20 pm
Your config is wrong on multiple accounts it seems.
I understand you want to bridge wlan0 and eth0 and run a single network off them. If so:
1.a- In /etc/network/interfaces, change "iface br0 inet manual" to "iface br0 inet static" and define the network parameters of the interface there,
then at the top of /etc/dhcpcd.conf, add "denyinterfaces eth0 wlan0 br0" and remove the "interface wlan0" block.
or
1.b- In /etc/dhcpcd.conf, add "denyinterfaces eth0 wlan0" at the top of the file and replace the "interface wlan0" block with the following:
interface br0
2. Make dnsmasq listen on br0 instead of wlan0, serve addresses on the network that br0 uses, within a range that does not clash with static addresses like the .10 used for br0
interface=br0
    dhcp-range=192.168.0.20,192.168.0.50,255.255.255.0,24h
eth0 and wlan0 are bridge member interfaces, they must have no IP configuration of their own. br0 must have a static IP configuration because the machine runs a DHCP server.
CloudOne
Wed May 22, 2019 9:29 pm
I tried to do what you've told me, in the first solution I stop having internet on the rpi but I have on the devices connected and the second one hasn't worked for me. Apart from that I'm trying to make an isolated ap but without success, because I realised that all the clients connected to the network are been showed. The idea is to send information like ip, mac to a web server, I only want to send the information of known devices connected to that isolated ap not all the others.
epoch1970
Wed May 22, 2019 10:17 pm
How do you expect to connect the rpi to Internet? wifi, usb cable...
You came asking for a network setup...
What/where is this web server? What are you trying to achieve?
