Raspberry pi 3 b+ need two different wlan interface
Posted: Tue May 21, 2019 3:17 pm
by r1si91
I have a Raspberry pi3 b+ with internal wifi 2,4/5ghz wifi module.
I need at least 2 different wlan interfaces connectet each to different connection with a different IP.
So I bought 2 wifi USB dongle one Ralink Technology, Corp. RT2870/RT3070 Wireless Adapter and one Realtek Semiconductor Corp. RTL8188CUS 802.11n WLAN Adapter.
in fact with command lsusb appear:
Bus 001 Device 007: ID 0bda:8176 Realtek Semiconductor Corp. RTL8188CUS 802.11n WLAN Adapter
Bus 001 Device 005: ID 148f:3070 Ralink Technology, Corp. RT2870/RT3070 Wireless Adapter
Bus 001 Device 004: ID 0424:7800 Standard Microsystems Corp.
Bus 001 Device 003: ID 0424:2514 Standard Microsystems Corp. USB 2.0 Hub
Bus 001 Device 002: ID 0424:2514 Standard Microsystems Corp. USB 2.0 Hub
but with ifconfig have only this interfaces:
enxb827eb3c0396: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 192.168.178.57  netmask 255.255.255.0  broadcast 192.168.178.255
        inet6 fe80::c78:a11f:ba08:da61  prefixlen 64  scopeid 0x20<link>
        ether b8:27:eb:3c:03:96  txqueuelen 1000  (Ethernet)
        RX packets 180524481  bytes 2868692719 (2.6 GiB)
        RX errors 47  dropped 489104  overruns 0  frame 5
        TX packets 151184830  bytes 163078366 (155.5 MiB)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
        inet 127.0.0.1  netmask 255.0.0.0
        inet6 ::1  prefixlen 128  scopeid 0x10<host>
        loop  txqueuelen 1000  (Local Loopback)
        RX packets 450688  bytes 22516261 (21.4 MiB)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 450688  bytes 22516261 (21.4 MiB)
wlan0: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
        ether b8:27:eb:69:56:c3  txqueuelen 1000  (Ethernet)
        RX packets 0  bytes 0 (0.0 B)
        TX packets 0  bytes 0 (0.0 B)
where wlan0 is internal raspberry wifi.
infact with iwlist wlan0 scan show me all 5Ghz/2.4Ghz connection ( my two dongles are 2.4 only)
how can I configure and add wlan1 and wlan2 to my raspberry?
Re: Raspberry pi 3 b+ need two different wlan interface
Posted: Wed May 22, 2019 10:26 am
by r1si91
Fixed with a simple reboot !!
the new interfaces will be generated on boot.
