Beller
WordPress not loading correctly
Mon May 20, 2019 7:17 am
Hello!
I've followed this tutorial to install LAMP stack https://projects.raspberrypi.org/en/pro ... wordpress/
And it was all loading fine for a few days... then I log in and see this (attached).
I can't really find anything online to help, wondering if there's a simple fix or if I should just uninstall and reinstall wordpress again - if so does anyone have exact commands for this too cause I've confused myself and don't want to ruin anything.
Might just need to wipe SD and start again? Didn't have on the Wordpress yet so not needing to back anything up at this stage.
Thank you!
wordpress issue
Andyroo
Re: WordPress not loading correctly
Tue May 21, 2019 1:06 am
Have you changed the IP address of the Pi since you loaded WP?
Did you install WP as localhost?
WP has the odd habit of embedding graphics with the full URL rather than a relative URL and it can get very mixed up on a good day.
There are a few add-ins designed for moving sites that can fix this for you or you can run some SQL if you have access (e.g. https://wpbeaches.com/updating-wordpres ... a-new-url/)
Please take a backup first though just in case...
