tmxk4197
How can I scan between LoRa using the LoRa (sx1278) module?
Sat May 18, 2019 2:39 pm
I am using two Dragino LoRa / GPS HATs to attach to the raspberry pie and try LoRa communication.
I also want to communicate LoRa over an IPv6 address.
To do so, I think we should have a physical connection between LoRa.
But I do not know how to do this and I do not know how to make a physical connection.
Does anyone know how to do this?
I would appreciate your reply.
Andyroo
Re: How can I scan between LoRa using the LoRa (sx1278) module?
Sat May 18, 2019 3:29 pm
If you are talking about just using point to point communications and not the LoRaWAN system then this library may be of help https://github.com/YandievRuslan/sx1278 ... aspberryPi if you can code in C
tmxk4197
Sat May 18, 2019 4:39 pm
Thank you for your reply !!
If so, can I use the above API to place the same scope link address between LoRa modules?
Andyroo
Sat May 18, 2019 4:58 pm
I do not think that you have to issue any Pi addresses with point 2 point mode - it just broadcasts to anything in range.
