I installed ovpn on my Raspberry and it was working perfectly.
Then I disabled wifi and put an Ethernet cable.
Since this moment the ovpn connection doesn't allow internet. Local network connection is working. I can't ping 8.8.8.8 for example, it's just the internet not "forwarded". But the raspberry is connected to the internet.
I think this is a stupid problem, but just in the ssh/Linux like I have totally no idea where to look for.
Can someone point me in the right file to edit/check? Thank you!
Re: From wifi to ethernet on OVPN no more internet connection
Have you thought about using their support service at https://www.ovpn.com/en/contact
I would try them first.
- default_user8
This is a configuration issue in your pi not opvn. Did you give your pi a static ip address in dhcpcd.conf? If so you need to change which adapter is getting the static ip, wlan(wifi) or eth0(ethernet). If you didn't setup a static ip you should, your pi will get a different ip address on the wifi and the ethernet connection. Since you switched to ethernet did you make the appropriate changes to point ovpn in the rigjt direction?
Two heads are better than one, unless one's a goat head.
