Piita
Ethernet Adapter RPi Zero Problems
Mon Mar 18, 2019 3:30 pm
I'm trying to connect a stack of Raspberry Pi Zero's (50) through a network switch. I'm using an USB ethernet adapter (10/100 Mbit Realtek 8152 based). Most Zero's appear to function fine everytime, but some Pis randomly don't start up well. I don't think it's a power problem, there is sufficient supply with good cabling. I have also not measured voltage drops.
I checked dmesg while it started up well, and I also logged dmesg when the startup was not successful (and the Pi didn't come online). I will post both logs. The problem seems to be:
[    6.230723] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[    6.402937] Indeed it is in host mode hprt0 = 00001101
[    6.962886] usb 1-1: device descriptor read/64, error -110
[    7.080689] systemd-journald[90]: Received request to flush runtime journal from PID 1
[    7.083584] Indeed it is in host mode hprt0 = 00001101
[    7.179077] systemd-journald[90]: File /var/log/journal/a12446eedc8043cc8785fac14a26c632/system.journal corrupted or uncleanly shut down, renaming and replacing.
[    7.542844] usb 1-1: device descriptor read/64, error -71
[    7.663107] Indeed it is in host mode hprt0 = 00001101
[    8.102837] usb 1-1: new high-speed USB device number 3 using dwc_otg
GOOD STARTUP
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 4.9.59+ ([email protected]) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611) ) #1047 Sun Oct 29 11:47:10 GMT 2017
[    0.000000] CPU: ARMv6-compatible processor [410fb767] revision 7 (ARMv7), cr=00c5387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
[    0.000000] OF: fdt:Machine model: Raspberry Pi Zero Rev 1.3
[    0.000000] cma: Reserved 8 MiB at 0x17400000
[    0.000000] Memory policy: Data cache writeback
[    0.000000] On node 0 totalpages: 98304
[    0.000000] free_area_init_node: node 0, pgdat c0914e10, node_mem_map d7c8be00
[    0.000000]   Normal zone: 864 pages used for memmap
[    0.000000]   Normal zone: 0 pages reserved
[    0.000000]   Normal zone: 98304 pages, LIFO batch:31
[    0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[    0.000000] pcpu-alloc: [0] 0
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 97440
[    0.000000] Kernel command line: bcm2708_fb.fbwidth=1824 bcm2708_fb.fbheight=984 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x1ec00000 vc_mem.mem_size=0x20000000  dwc_otg.lpm_enable=0 usbcore.use_both_schemes=Y dwc_otg.dma_enable=1 dwc_otg.dma_burst_size=256 smsc95xx.turbo_mode=N console=ttyAMA0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
[    0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[    0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.000000] Memory: 370984K/393216K available (5950K kernel code, 491K rwdata, 1948K rodata, 396K init, 725K bss, 14040K reserved, 8192K cma-reserved)
[    0.000000] Virtual kernel memory layout:
                   vector  : 0xffff0000 - 0xffff1000   (   4 kB)
                   fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
                   vmalloc : 0xd8800000 - 0xff800000   ( 624 MB)
                   lowmem  : 0xc0000000 - 0xd8000000   ( 384 MB)
                   modules : 0xbf000000 - 0xc0000000   (  16 MB)
                     .text : 0xc0008000 - 0xc05d7a48   (5951 kB)
                     .init : 0xc0841000 - 0xc08a4000   ( 396 kB)
                     .data : 0xc08a4000 - 0xc091ef48   ( 492 kB)
                      .bss : 0xc091ef48 - 0xc09d4648   ( 726 kB)
[    0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[    0.000000] NR_IRQS:16 nr_irqs:16 16
[    0.000032] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
[    0.000063] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
[    0.000157] bcm2835: system timer (irq = 27)
[    0.000616] Console: colour dummy device 80x30
[    0.000641] console [tty1] enabled
[    0.000667] Calibrating delay loop... 697.95 BogoMIPS (lpj=3489792)
[    0.060316] pid_max: default: 32768 minimum: 301
[    0.060743] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.060760] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.062007] Disabling memory control group subsystem
[    0.062146] CPU: Testing write buffer coherency: ok
[    0.062202] ftrace: allocating 21715 entries in 64 pages
[    0.180461] Setting up static identity map for 0x8200 - 0x8238
[    0.182444] devtmpfs: initialized
[    0.192426] VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5
[    0.192860] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.192887] futex hash table entries: 256 (order: -1, 3072 bytes)
[    0.194173] pinctrl core: initialized pinctrl subsystem
[    0.195599] NET: Registered protocol family 16
[    0.198258] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[    0.208044] hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
[    0.208061] hw-breakpoint: maximum watchpoint size is 4 bytes.
[    0.208163] Serial: AMBA PL011 UART driver
[    0.211060] bcm2835-mbox 2000b880.mailbox: mailbox enabled
[    0.261666] bcm2835-dma 20007000.dma: DMA legacy API manager at d880d000, dmachans=0x1
[    0.264329] SCSI subsystem initialized
[    0.264591] usbcore: registered new interface driver usbfs
[    0.264709] usbcore: registered new interface driver hub
[    0.264903] usbcore: registered new device driver usb
[    0.270543] raspberrypi-firmware soc:firmware: Attached to firmware from 2017-10-24 17:13
[    0.272673] clocksource: Switched to clocksource timer
[    0.326791] VFS: Disk quotas dquot_6.6.0
[    0.326912] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.327232] FS-Cache: Loaded
[    0.327575] CacheFiles: Loaded
[    0.346970] NET: Registered protocol family 2
[    0.348315] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
[    0.348406] TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
[    0.348500] TCP: Hash tables configured (established 4096 bind 4096)
[    0.348600] UDP hash table entries: 256 (order: 0, 4096 bytes)
[    0.348627] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[    0.348941] NET: Registered protocol family 1
[    0.349679] RPC: Registered named UNIX socket transport module.
[    0.349690] RPC: Registered udp transport module.
[    0.349695] RPC: Registered tcp transport module.
[    0.349700] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.351068] hw perfevents: enabled with armv6_1176 PMU driver, 3 counters available
[    0.353599] workingset: timestamp_bits=14 max_order=17 bucket_order=3
[    0.374280] FS-Cache: Netfs 'nfs' registered for caching
[    0.376039] NFS: Registering the id_resolver key type
[    0.376085] Key type id_resolver registered
[    0.376092] Key type id_legacy registered
[    0.380551] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
[    0.380915] io scheduler noop registered
[    0.380928] io scheduler deadline registered (default)
[    0.381397] io scheduler cfq registered
[    0.387398] BCM2708FB: allocated DMA memory 57500000
[    0.387457] BCM2708FB: allocated DMA channel 0 @ d880d000
[    0.432246] Console: switching to colour frame buffer device 228x61
[    0.468972] bcm2835-rng 20104000.rng: hwrng registered
[    0.469159] vc-mem: phys_addr:0x00000000 mem_base=0x1ec00000 mem_size:0x20000000(512 MiB)
[    0.470230] vc-sm: Videocore shared memory driver
[    0.497862] brd: module loaded
[    0.511643] loop: module loaded
[    0.511669] Loading iSCSI transport class v2.0-870.
[    0.512813] usbcore: registered new interface driver smsc95xx
[    0.512849] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[    0.741376] Core Release: 2.80a
[    0.741407] Setting default values for core params
[    0.741455] Finished setting default values for core params
[    0.942010] Using Buffer DMA mode
[    0.942026] Periodic Transfer Interrupt Enhancement - disabled
[    0.942031] Multiprocessor Interrupt Enhancement - disabled
[    0.942043] OTG VER PARAM: 0, OTG VER FLAG: 0
[    0.942148] Dedicated Tx FIFOs mode
[    0.943015] WARN::dwc_otg_hcd_init:1032: FIQ DMA bounce buffers: virt = 0xd7514000 dma = 0x57514000 len=9024
[    0.943047] FIQ FSM acceleration enabled for :
               Non-periodic Split Transactions
               Periodic Split Transactions
               High-Speed Isochronous Endpoints
               Interrupt/Control Split Transaction hack enabled
[    0.943060] dwc_otg: Microframe scheduler enabled
[    0.943160] WARN::hcd_init_fiq:459: FIQ on core 0 at 0xc0451694
[    0.943175] WARN::hcd_init_fiq:460: FIQ ASM at 0xc0451970 length 36
[    0.943204] WARN::hcd_init_fiq:486: MPHI regs_base at 0xd88a5000
[    0.943286] dwc_otg 20980000.usb: DWC OTG Controller
[    0.943358] dwc_otg 20980000.usb: new USB bus registered, assigned bus number 1
[    0.943488] dwc_otg 20980000.usb: irq 56, io mem 0x00000000
[    0.943548] Init: Port Power? op_state=1
[    0.943554] Init: Power Port (0)
[    0.944009] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    0.944028] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.944041] usb usb1: Product: DWC OTG Controller
[    0.944053] usb usb1: Manufacturer: Linux 4.9.59+ dwc_otg_hcd
[    0.944063] usb usb1: SerialNumber: 20980000.usb
[    0.945386] hub 1-0:1.0: USB hub found
[    0.945493] hub 1-0:1.0: 1 port detected
[    0.946591] dwc_otg: FIQ enabled
[    0.946604] dwc_otg: NAK holdoff enabled
[    0.946611] dwc_otg: FIQ split-transaction FSM enabled
[    0.946634] Module dwc_common_port init
[    0.947214] usbcore: registered new interface driver usb-storage
[    0.947738] mousedev: PS/2 mouse device common for all mice
[    0.949669] bcm2835-wdt 20100000.watchdog: Broadcom BCM2835 watchdog timer
[    0.950243] bcm2835-cpufreq: min=700000 max=1000000
[    0.950939] sdhci: Secure Digital Host Controller Interface driver
[    0.950948] sdhci: Copyright(c) Pierre Ossman
[    0.951474] sdhost-bcm2835 20202000.sdhost: could not get clk, deferring probe
[    0.951827] sdhci-pltfm: SDHCI platform and OF driver helper
[    0.952762] ledtrig-cpu: registered to indicate activity on CPUs
[    0.952998] hidraw: raw HID events driver (C) Jiri Kosina
[    0.953303] usbcore: registered new interface driver usbhid
[    0.953313] usbhid: USB HID core driver
[    0.954651] vchiq: vchiq_init_state: slot_zero = 0xd7580000, is_master = 0
[    0.956553] [vc_sm_connected_init]: start
[    0.967556] [vc_sm_connected_init]: end - returning 0
[    0.968115] Initializing XFRM netlink socket
[    0.968160] NET: Registered protocol family 17
[    0.968341] Key type dns_resolver registered
[    0.970569] registered taskstats version 1
[    0.978490] uart-pl011 20201000.serial: cts_event_workaround enabled
[    0.978643] 20201000.serial: ttyAMA0 at MMIO 0x20201000 (irq = 81, base_baud = 0) is a PL011 rev2
[    0.978756] console [ttyAMA0] enabled
[    0.981554] sdhost: log_buf @ d7513000 (57513000)
[    1.052768] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[    1.052998] of_cfs_init
[    1.053140] of_cfs_init: OK
[    1.054210] Waiting for root device /dev/mmcblk0p2...
[    1.084682] random: fast init done
[    1.162988] Indeed it is in host mode hprt0 = 00021501
[    1.232854] mmc0: host does not support reading read-only switch, assuming write-enable
[    1.236831] mmc0: new high speed SDHC card at address aaaa
[    1.238187] mmcblk0: mmc0:aaaa SL08G 7.40 GiB
[    1.240693]  mmcblk0: p1 p2
[    1.360268] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[    1.360415] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[    1.361732] devtmpfs: mounted
[    1.363405] Freeing unused kernel memory: 396K
[    1.363418] This architecture does not have kernel memory protection.
[    1.363476] usb 1-1: new high-speed USB device number 2 using dwc_otg
[    1.363785] Indeed it is in host mode hprt0 = 00001101
[    1.595054] usb 1-1: New USB device found, idVendor=0bda, idProduct=8152
[    1.595107] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    1.595121] usb 1-1: Product: USB 10/100 LAN
[    1.595132] usb 1-1: Manufacturer: Realtek
[    1.595141] usb 1-1: SerialNumber: 00E04C36000E
[    1.958877] systemd[1]: System time before build time, advancing clock.
[    2.122444] NET: Registered protocol family 10
[    2.140561] ip_tables: (C) 2000-2006 Netfilter Core Team
[    2.193272] systemd[1]: systemd 232 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN)
[    2.194774] systemd[1]: Detected architecture arm.
[    2.207944] systemd[1]: Set hostname to <MX9>.
[    2.618597] uart-pl011 20201000.serial: no DMA platform data
[    3.418644] systemd[1]: Listening on udev Kernel Socket.
[    3.420378] systemd[1]: Listening on Journal Socket (/dev/log).
[    3.421218] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[    3.422046] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    3.424251] systemd[1]: Created slice System Slice.
[    3.426322] systemd[1]: Created slice system-serial\x2dgetty.slice.
[    3.429841] systemd[1]: Created slice system-autologin.slice.
[    3.826562] random: crng init done
[    3.880920] i2c /dev entries driver
[    6.142868] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[    6.873763] systemd-journald[99]: Received request to flush runtime journal from PID 1
[    6.902184] systemd-journald[99]: File /var/log/journal/a12446eedc8043cc8785fac14a26c632/system.journal corrupted or uncleanly shut down, renaming and replacing.
[    9.942971] gpiomem-bcm2835 20200000.gpiomem: Initialised: Registers at 0x20200000
[   11.975841] Indeed it is in host mode hprt0 = 00001101
[   12.038234] usbcore: registered new interface driver r8152
[   12.046755] usbcore: registered new interface driver cdc_ether
[   12.372884] usb 1-1: reset high-speed USB device number 2 using dwc_otg
[   12.373376] Indeed it is in host mode hprt0 = 00001101
[   13.006050] r8152 1-1:1.0 eth0: v1.08.8
[   20.209036] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   20.228791] r8152 1-1:1.0 eth0: carrier on
[   20.229966] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[   20.334668] IPv6: eth0: IPv6 duplicate address fd51:42f8:caae:d92e::ff detected!
[   21.844597] IPv6: eth0: IPv6 duplicate address fd51:42f8:caae:d92e::ff detected!
[   23.583479] Adding 102396k swap on /var/swap.  Priority:-1 extents:1 across:102396k SSFS
[   44.895520] r8152 1-1:1.0 eth0: Rx status -71
[   44.895668] r8152 1-1:1.0 eth0: Rx status -71
[   45.133263] usb usb1-port1: disabled by hub (EMI?), re-enabling...
[   45.133309] usb 1-1: USB disconnect, device number 2
[   45.363042] Indeed it is in host mode hprt0 = 00001101
[   45.632895] usb 1-1: new high-speed USB device number 3 using dwc_otg
[   45.633261] NYET/NAK/ACK/other in non-error case, 0x00000002
[   45.633294] NYET/NAK/ACK/other in non-error case, 0x00000002
[   45.633326] NYET/NAK/ACK/other in non-error case, 0x00000002
[   45.633398] NYET/NAK/ACK/other in non-error case, 0x00000002
[   45.633427] NYET/NAK/ACK/other in non-error case, 0x00000002
[   45.633458] NYET/NAK/ACK/other in non-error case, 0x00000002
[   45.633527] Indeed it is in host mode hprt0 = 00001101
[   45.972923] usb 1-1: device descriptor read/64, error -71
[   46.093491] Indeed it is in host mode hprt0 = 00001101
[   46.402922] usb 1-1: device descriptor read/64, error -71
[   46.523282] Indeed it is in host mode hprt0 = 00001101
[   46.872867] usb 1-1: new high-speed USB device number 4 using dwc_otg
[   46.873559] Indeed it is in host mode hprt0 = 00001101
[   47.182943] usb 1-1: device descriptor read/64, error -71
[   47.303527] Indeed it is in host mode hprt0 = 00001101
[   47.532914] usb 1-1: device descriptor read/64, error -71
[   47.653134] Indeed it is in host mode hprt0 = 00001101
[   47.872908] usb 1-1: new high-speed USB device number 5 using dwc_otg
[   48.313006] usb 1-1: device not accepting address 5, error -71
[   48.313266] Indeed it is in host mode hprt0 = 00001101
[   48.552869] usb 1-1: new high-speed USB device number 6 using dwc_otg
[   48.553010] NYET/NAK/ACK/other in non-error case, 0x00000002
[   48.553045] NYET/NAK/ACK/other in non-error case, 0x00000002
[   48.772856] NYET/NAK/ACK/other in non-error case, 0x00000002
[   48.772897] NYET/NAK/ACK/other in non-error case, 0x00000002
[   48.772924] NYET/NAK/ACK/other in non-error case, 0x00000002
[   48.992905] usb 1-1: device not accepting address 6, error -71
[   48.993091] usb usb1-port1: unable to enumerate USB device
[   50.978630] usbcore: deregistering interface driver r8152
[   52.583107] Indeed it is in host mode hprt0 = 00041901
[   52.852891] usb 1-1: new low-speed USB device number 7 using dwc_otg
[   52.854325] Indeed it is in host mode hprt0 = 00041901
[   53.078682] usbcore: registered new interface driver r8152
[   53.161434] usb 1-1: New USB device found, idVendor=413c, idProduct=2107
[   53.161456] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[   53.161464] usb 1-1: Product: Dell USB Entry Keyboard
[   53.161472] usb 1-1: Manufacturer: Dell
[   53.216818] input: Dell Dell USB Entry Keyboard as /devices/platform/soc/20980000.usb/usb1/1-1/1-1:1.0/0003:413C:2107.0001/input/input0
[   53.290346] hid-generic 0003:413C:2107.0001: input,hidraw0: USB HID v1.10 Keyboard [Dell Dell USB Entry Keyboard] on usb-20980000.usb-1/input0
[   69.290365] usbcore: deregistering interface driver r8152
[   69.383263] usb 1-1: USB disconnect, device number 7
[   71.083209] Indeed it is in host mode hprt0 = 00041901
[   71.352903] usb 1-1: new low-speed USB device number 8 using dwc_otg
[   71.357907] Indeed it is in host mode hprt0 = 00041901
[   71.493093] usbcore: registered new interface driver r8152
[   71.671111] usb 1-1: New USB device found, idVendor=413c, idProduct=2107
[   71.671134] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[   71.671141] usb 1-1: Product: Dell USB Entry Keyboard
[   71.671148] usb 1-1: Manufacturer: Dell
[   71.727795] input: Dell Dell USB Entry Keyboard as /devices/platform/soc/20980000.usb/usb1/1-1/1-1:1.0/0003:413C:2107.0002/input/input1
[   71.799253] hid-generic 0003:413C:2107.0002: input,hidraw0: USB HID v1.10 Keyboard [Dell Dell USB Entry Keyboard] on usb-20980000.usb-1/input0
WRONG STARTUP
[    0.000617] Console: colour dummy device 80x30
[    0.000642] console [tty1] enabled
[    0.060323] pid_max: default: 32768 minimum: 301
[    0.060749] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.060767] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.062013] Disabling memory control group subsystem
[    0.062151] CPU: Testing write buffer coherency: ok
[    0.062208] ftrace: allocating 21715 entries in 64 pages
[    0.180450] Setting up static identity map for 0x8200 - 0x8238
[    0.182425] devtmpfs: initialized
[    0.192413] VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5
[    0.192845] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.192871] futex hash table entries: 256 (order: -1, 3072 bytes)
[    0.194158] pinctrl core: initialized pinctrl subsystem
[    0.195586] NET: Registered protocol family 16
[    0.198242] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[    0.208037] hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
[    0.208053] hw-breakpoint: maximum watchpoint size is 4 bytes.
[    0.208155] Serial: AMBA PL011 UART driver
[    0.211048] bcm2835-mbox 2000b880.mailbox: mailbox enabled
[    0.261620] bcm2835-dma 20007000.dma: DMA legacy API manager at d880d000, dmachans=0x1
[    0.264272] SCSI subsystem initialized
[    0.264538] usbcore: registered new interface driver usbfs
[    0.264656] usbcore: registered new interface driver hub
[    0.264850] usbcore: registered new device driver usb
[    0.270529] raspberrypi-firmware soc:firmware: Attached to firmware from 2017-10-24 17:13
[    0.272661] clocksource: Switched to clocksource timer
[    0.326768] VFS: Disk quotas dquot_6.6.0
[    0.326888] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.327209] FS-Cache: Loaded
[    0.327550] CacheFiles: Loaded
[    0.346934] NET: Registered protocol family 2
[    0.348277] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
[    0.348367] TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
[    0.348463] TCP: Hash tables configured (established 4096 bind 4096)
[    0.348562] UDP hash table entries: 256 (order: 0, 4096 bytes)
[    0.348589] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[    0.348898] NET: Registered protocol family 1
[    0.349641] RPC: Registered named UNIX socket transport module.
[    0.349653] RPC: Registered udp transport module.
[    0.349658] RPC: Registered tcp transport module.
[    0.349663] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.351031] hw perfevents: enabled with armv6_1176 PMU driver, 3 counters available
[    0.353543] workingset: timestamp_bits=14 max_order=17 bucket_order=3
[    0.374227] FS-Cache: Netfs 'nfs' registered for caching
[    0.375992] NFS: Registering the id_resolver key type
[    0.376038] Key type id_resolver registered
[    0.376045] Key type id_legacy registered
[    0.380513] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
[    0.380880] io scheduler noop registered
[    0.380894] io scheduler deadline registered (default)
[    0.381363] io scheduler cfq registered
[    0.387367] BCM2708FB: allocated DMA memory 57500000
[    0.387427] BCM2708FB: allocated DMA channel 0 @ d880d000
[    0.432388] Console: switching to colour frame buffer device 228x61
[    0.469137] bcm2835-rng 20104000.rng: hwrng registered
[    0.469323] vc-mem: phys_addr:0x00000000 mem_base=0x1ec00000 mem_size:0x20000000(512 MiB)
[    0.470268] vc-sm: Videocore shared memory driver
[    0.497993] brd: module loaded
[    0.511833] loop: module loaded
[    0.511859] Loading iSCSI transport class v2.0-870.
[    0.513015] usbcore: registered new interface driver smsc95xx
[    0.513048] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[    0.741590] Core Release: 2.80a
[    0.741621] Setting default values for core params
[    0.741667] Finished setting default values for core params
[    0.942233] Using Buffer DMA mode
[    0.942249] Periodic Transfer Interrupt Enhancement - disabled
[    0.942256] Multiprocessor Interrupt Enhancement - disabled
[    0.942265] OTG VER PARAM: 0, OTG VER FLAG: 0
[    0.942372] Dedicated Tx FIFOs mode
[    0.943220] WARN::dwc_otg_hcd_init:1032: FIQ DMA bounce buffers: virt = 0xd7514000 dma = 0x57514000 len=9024
[    0.943253] FIQ FSM acceleration enabled for :
[    0.943266] dwc_otg: Microframe scheduler enabled
[    0.943365] WARN::hcd_init_fiq:459: FIQ on core 0 at 0xc0451694
[    0.943380] WARN::hcd_init_fiq:460: FIQ ASM at 0xc0451970 length 36
[    0.943409] WARN::hcd_init_fiq:486: MPHI regs_base at 0xd88a5000
[    0.943489] dwc_otg 20980000.usb: DWC OTG Controller
[    0.943561] dwc_otg 20980000.usb: new USB bus registered, assigned bus number 1
[    0.943685] dwc_otg 20980000.usb: irq 56, io mem 0x00000000
[    0.943747] Init: Port Power? op_state=1
[    0.943754] Init: Power Port (0)
[    0.944206] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    0.944227] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.944240] usb usb1: Product: DWC OTG Controller
[    0.944249] usb usb1: Manufacturer: Linux 4.9.59+ dwc_otg_hcd
[    0.944260] usb usb1: SerialNumber: 20980000.usb
[    0.945580] hub 1-0:1.0: USB hub found
[    0.945687] hub 1-0:1.0: 1 port detected
[    0.946779] dwc_otg: FIQ enabled
[    0.946792] dwc_otg: NAK holdoff enabled
[    0.946798] dwc_otg: FIQ split-transaction FSM enabled
[    0.946822] Module dwc_common_port init
[    0.947401] usbcore: registered new interface driver usb-storage
[    0.947919] mousedev: PS/2 mouse device common for all mice
[    0.949859] bcm2835-wdt 20100000.watchdog: Broadcom BCM2835 watchdog timer
[    0.950402] bcm2835-cpufreq: min=700000 max=1000000
[    0.951090] sdhci: Secure Digital Host Controller Interface driver
[    0.951101] sdhci: Copyright(c) Pierre Ossman
[    0.951623] sdhost-bcm2835 20202000.sdhost: could not get clk, deferring probe
[    0.951975] sdhci-pltfm: SDHCI platform and OF driver helper
[    0.952917] ledtrig-cpu: registered to indicate activity on CPUs
[    0.953107] hidraw: raw HID events driver (C) Jiri Kosina
[    0.953374] usbcore: registered new interface driver usbhid
[    0.953381] usbhid: USB HID core driver
[    0.954610] vchiq: vchiq_init_state: slot_zero = 0xd7580000, is_master = 0
[    0.956700] [vc_sm_connected_init]: start
[    0.967710] [vc_sm_connected_init]: end - returning 0
[    0.968261] Initializing XFRM netlink socket
[    0.968307] NET: Registered protocol family 17
[    0.968493] Key type dns_resolver registered
[    0.970537] registered taskstats version 1
[    0.978621] uart-pl011 20201000.serial: cts_event_workaround enabled
[    0.978774] 20201000.serial: ttyAMA0 at MMIO 0x20201000 (irq = 81, base_baud = 0) is a PL011 rev2
[    0.978888] console [ttyAMA0] enabled
[    0.981740] sdhost: log_buf @ d7513000 (57513000)
[    1.062759] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[    1.083062] of_cfs_init
[    1.083207] of_cfs_init: OK
[    1.084293] Waiting for root device /dev/mmcblk0p2...
[    1.093948] random: fast init done
[    1.162961] Indeed it is in host mode hprt0 = 00021501
[    1.233247] mmc0: host does not support reading read-only switch, assuming write-enable
[    1.236937] mmc0: new high speed SDHC card at address aaaa
[    1.238202] mmcblk0: mmc0:aaaa SL08G 7.40 GiB
[    1.240947]  mmcblk0: p1 p2
[    1.362577] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[    1.362836] usb 1-1: new high-speed USB device number 2 using dwc_otg
[    1.363079] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[    1.364485] devtmpfs: mounted
[    1.366042] Freeing unused kernel memory: 396K
[    1.366053] This architecture does not have kernel memory protection.
[    1.902824] systemd[1]: System time before build time, advancing clock.
[    2.068628] NET: Registered protocol family 10
[    2.086778] ip_tables: (C) 2000-2006 Netfilter Core Team
[    2.139985] systemd[1]: systemd 232 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN)
[    2.141536] systemd[1]: Detected architecture arm.
[    2.154919] systemd[1]: Set hostname to <MX9>.
[    2.606623] uart-pl011 20201000.serial: no DMA platform data
[    3.373804] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    3.404900] systemd[1]: Listening on udev Control Socket.
[    3.406153] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    3.407269] systemd[1]: Listening on Syslog Socket.
[    3.408157] systemd[1]: Listening on fsck to fsckd communication Socket.
[    3.409135] systemd[1]: Listening on Journal Socket (/dev/log).
[    3.410213] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[    3.770925] random: crng init done
[    3.867271] i2c /dev entries driver
[    8.103318] Indeed it is in host mode hprt0 = 00001101
[    8.502886] usb 1-1: device descriptor read/64, error -71
[    8.623422] Indeed it is in host mode hprt0 = 00001101
[    8.972859] usb 1-1: device descriptor read/64, error -71
[    9.093156] Indeed it is in host mode hprt0 = 00001101
[    9.412993] usb 1-1: new high-speed USB device number 4 using dwc_otg
[    9.852903] usb 1-1: device not accepting address 4, error -71
[    9.853145] Indeed it is in host mode hprt0 = 00001101
[   10.152862] usb 1-1: new high-speed USB device number 5 using dwc_otg
[   10.592863] usb 1-1: device not accepting address 5, error -71
[   10.593079] usb usb1-port1: unable to enumerate USB device
[   11.261769] gpiomem-bcm2835 20200000.gpiomem: Initialised: Registers at 0x20200000
[   23.479817] Adding 102396k swap on /var/swap.  Priority:-1 extents:1 across:102396k SSFS
[   46.832998] Indeed it is in host mode hprt0 = 00021501
[   47.023312] usbcore: registered new interface driver r8152
[   47.092834] usb 1-1: new high-speed USB device number 6 using dwc_otg
[   47.093325] Indeed it is in host mode hprt0 = 00001101
[   47.362799] usb 1-1: device descriptor read/64, error -71
[   47.483193] Indeed it is in host mode hprt0 = 00001101
[   47.752951] usb 1-1: device descriptor read/64, error -71
[   47.873016] Indeed it is in host mode hprt0 = 00001101
[   48.132959] usb 1-1: new high-speed USB device number 7 using dwc_otg
[   48.133461] Indeed it is in host mode hprt0 = 00001101
[   48.402811] usb 1-1: device descriptor read/64, error -71
[   48.523279] Indeed it is in host mode hprt0 = 00001101
[   48.812787] usb 1-1: device descriptor read/64, error -71
[   48.932945] Indeed it is in host mode hprt0 = 00001101
[   49.212875] usb 1-1: new high-speed USB device number 8 using dwc_otg
[   49.652809] usb 1-1: device not accepting address 8, error -71
[   49.653020] Indeed it is in host mode hprt0 = 00001101
[   50.002826] usb 1-1: new high-speed USB device number 9 using dwc_otg
[   50.442802] usb 1-1: device not accepting address 9, error -71
[   50.442950] usb usb1-port1: unable to enumerate USB device
[   64.609344] usbcore: deregistering interface driver r8152
[   66.332970] Indeed it is in host mode hprt0 = 00021501
[   66.602813] usb 1-1: new high-speed USB device number 10 using dwc_otg
[   66.603259] Indeed it is in host mode hprt0 = 00001101
[   66.723036] usbcore: registered new interface driver r8152
[   66.902822] usb 1-1: device descriptor read/64, error -71
[   67.023181] Indeed it is in host mode hprt0 = 00001101
[   67.302838] usb 1-1: device descriptor read/64, error -71
[   67.423095] Indeed it is in host mode hprt0 = 00001101
[   67.682811] usb 1-1: new high-speed USB device number 11 using dwc_otg
[   67.683500] Indeed it is in host mode hprt0 = 00001101
[   67.952820] usb 1-1: device descriptor read/64, error -71
[   68.073180] Indeed it is in host mode hprt0 = 00001101
[   68.332861] usb 1-1: device descriptor read/64, error -71
[   68.452967] Indeed it is in host mode hprt0 = 00001101
[   68.732788] usb 1-1: new high-speed USB device number 12 using dwc_otg
[   69.176266] usb 1-1: device not accepting address 12, error -71
[   69.176466] Indeed it is in host mode hprt0 = 00001101
[   69.502868] usb 1-1: new high-speed USB device number 13 using dwc_otg
[   69.942817] usb 1-1: device not accepting address 13, error -71
[   69.942969] usb usb1-port1: unable to enumerate USB device
[   85.049701] usbcore: deregistering interface driver r8152
[   86.833022] Indeed it is in host mode hprt0 = 00021501
[   86.993102] usbcore: registered new interface driver r8152
[   87.106475] usb 1-1: new high-speed USB device number 14 using dwc_otg
[   87.106932] Indeed it is in host mode hprt0 = 00001101
[   87.372846] usb 1-1: device descriptor read/64, error -71
[   87.493374] Indeed it is in host mode hprt0 = 00001101
[   87.762850] usb 1-1: device descriptor read/64, error -71
[   87.883062] Indeed it is in host mode hprt0 = 00001101
[   88.142805] usb 1-1: new high-speed USB device number 15 using dwc_otg
[   88.143359] Indeed it is in host mode hprt0 = 00001101
[   88.412802] usb 1-1: device descriptor read/64, error -71
[   88.533387] Indeed it is in host mode hprt0 = 00001101
[   88.822830] usb 1-1: device descriptor read/64, error -71
[   88.943035] Indeed it is in host mode hprt0 = 00001101
[   89.202831] usb 1-1: new high-speed USB device number 16 using dwc_otg
[   89.642913] usb 1-1: device not accepting address 16, error -71
[   89.643109] Indeed it is in host mode hprt0 = 00001101
[   89.992842] usb 1-1: new high-speed USB device number 17 using dwc_otg
[   90.433447] usb 1-1: device not accepting address 17, error -71
[   90.433603] usb usb1-port1: unable to enumerate USB device
[  104.710315] usbcore: deregistering interface driver r8152
[  106.332982] Indeed it is in host mode hprt0 = 00021501
[  106.602812] usb 1-1: new high-speed USB device number 18 using dwc_otg
[  106.603240] Indeed it is in host mode hprt0 = 00001101
[  106.788517] usbcore: registered new interface driver r8152
[  106.872834] usb 1-1: device descriptor read/64, error -71
[  106.993224] Indeed it is in host mode hprt0 = 00001101
[  107.262816] usb 1-1: device descriptor read/64, error -71
[  107.383044] Indeed it is in host mode hprt0 = 00001101
[  107.643144] usb 1-1: new high-speed USB device number 19 using dwc_otg
[  107.643526] Indeed it is in host mode hprt0 = 00001101
[  107.912860] usb 1-1: device descriptor read/64, error -71
[  108.033442] Indeed it is in host mode hprt0 = 00001101
[  108.302884] usb 1-1: device descriptor read/64, error -71
[  108.422971] Indeed it is in host mode hprt0 = 00001101
[  108.702788] usb 1-1: new high-speed USB device number 20 using dwc_otg
[  109.142805] usb 1-1: device not accepting address 20, error -71
[  109.143005] Indeed it is in host mode hprt0 = 00001101
[  109.502846] usb 1-1: new high-speed USB device number 21 using dwc_otg
[  109.942832] usb 1-1: device not accepting address 21, error -71
[  109.942982] usb usb1-port1: unable to enumerate USB device
[  125.165360] usbcore: deregistering interface driver r8152
[  126.833132] Indeed it is in host mode hprt0 = 00021501
[  127.102830] usb 1-1: new high-speed USB device number 22 using dwc_otg
[  127.103326] Indeed it is in host mode hprt0 = 00001101
[  127.249232] usbcore: registered new interface driver r8152
[  127.382835] usb 1-1: device descriptor read/64, error -71
[  127.503217] Indeed it is in host mode hprt0 = 00001101
[  127.782806] usb 1-1: device descriptor read/64, error -71
[  127.902973] Indeed it is in host mode hprt0 = 00001101
[  128.162826] usb 1-1: new high-speed USB device number 23 using dwc_otg
[  128.163335] Indeed it is in host mode hprt0 = 00001101
[  128.432805] usb 1-1: device descriptor read/64, error -71
[  128.553373] Indeed it is in host mode hprt0 = 00001101
[  128.822864] usb 1-1: device descriptor read/64, error -71
[  128.942982] Indeed it is in host mode hprt0 = 00001101
[  129.212844] usb 1-1: new high-speed USB device number 24 using dwc_otg
[  129.652812] usb 1-1: device not accepting address 24, error -71
[  129.653019] Indeed it is in host mode hprt0 = 00001101
[  129.982796] usb 1-1: new high-speed USB device number 25 using dwc_otg
[  130.422780] usb 1-1: device not accepting address 25, error -71
[  130.422928] usb usb1-port1: unable to enumerate USB device
[  144.789380] usbcore: deregistering interface driver r8152
[  146.582972] Indeed it is in host mode hprt0 = 00041901
[  146.719202] usbcore: registered new interface driver r8152
[  146.862874] usb 1-1: new low-speed USB device number 26 using dwc_otg
[  146.864392] Indeed it is in host mode hprt0 = 00041901
[  147.170958] usb 1-1: New USB device found, idVendor=413c, idProduct=2107
[  147.170976] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[  147.170983] usb 1-1: Product: Dell USB Entry Keyboard
[  147.170990] usb 1-1: Manufacturer: Dell
[  147.207516] input: Dell Dell USB Entry Keyboard as /devices/platform/soc/20980000.usb/usb1/1-1/1-1:1.0/0003:413C:2107.0001/input/input0
[  147.277314] hid-generic 0003:413C:2107.0001: input,hidraw0: USB HID v1.10 Keyboard [Dell Dell USB Entry Keyboard] on usb-20980000.usb-1/input0
[  165.132992] usb 1-1: USB disconnect, device number 26
[  165.391564] usbcore: deregistering interface driver r8152
[  167.082901] Indeed it is in host mode hprt0 = 00041901
[  167.351302] usbcore: registered new interface driver r8152
[  167.354196] usb 1-1: new low-speed USB device number 27 using dwc_otg
[  167.358434] Indeed it is in host mode hprt0 = 00041901
[  167.670822] usb 1-1: New USB device found, idVendor=413c, idProduct=2107
[  167.670840] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[  167.670849] usb 1-1: Product: Dell USB Entry Keyboard
[  167.670855] usb 1-1: Manufacturer: Dell
[  167.692501] input: Dell Dell USB Entry Keyboard as /devices/platform/soc/20980000.usb/usb1/1-1/1-1:1.0/0003:413C:2107.0002/input/input1
[  167.757291] hid-generic 0003:413C:2107.0002: input,hidraw0: USB HID v1.10 Keyboard [Dell Dell USB Entry Keyboard] on usb-20980000.usb-1/input0
[  184.849558] usbcore: deregistering interface driver r8152
[  184.883026] usb 1-1: USB disconnect, device number 27
[  186.582990] Indeed it is in host mode hprt0 = 00041901
[  186.842870] usb 1-1: new low-speed USB device number 28 using dwc_otg
[  186.844387] Indeed it is in host mode hprt0 = 00041901
[  187.038894] usbcore: registered new interface driver r8152
[  187.154949] usb 1-1: New USB device found, idVendor=413c, idProduct=2107
[  187.154966] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[  187.154974] usb 1-1: Product: Dell USB Entry Keyboard
[  187.154981] usb 1-1: Manufacturer: Dell
[  187.177862] input: Dell Dell USB Entry Keyboard as /devices/platform/soc/20980000.usb/usb1/1-1/1-1:1.0/0003:413C:2107.0003/input/input2
[  187.247599] hid-generic 0003:413C:2107.0003: input,hidraw0: USB HID v1.10 Keyboard [Dell Dell USB Entry Keyboard] on usb-20980000.usb-1/input0
I could really use some insight into what could be wrong here! Thanks a lot in advance!
RattusRattus
Re: Ethernet Adapter RPi Zero Problems
Fri Mar 22, 2019 11:39 am
Your logs seem to suggest a USB subsystem problem, but other than that...
Lets try some basic fault finding
1) is it always the SAME Pis that have this error?
You mention that some Pis randomly don't start as expected... is it always the same Pis that fail to start (i.e. does Pi #1 always work but Pi #2 sometimes works and sometimes fails?)
2) Are you moving Pis around in your rig are is the SAME Pi always in the same location?
i.e. does the fault follow physical location (note location may not always fail, but do failures always happen at given physical locations? has the fault been shown to happen at ALL locations?)
3) Are you moving uSD cards around?
i.e. does the fault condition only happen on SOME uSD cards but not others?
4) What happens if you only run a stack of 5 Pis - do you still get the fault
i.e. is this a scale problem (power supply / decoupling / hold-up / cross talk)?
What we are trying to do here is to narrow down the possible conditions causing the fault...
/Rattus
fd_
Sun Oct 13, 2019 10:53 am
Did you find a solution to the problem? I think I'm seeing the same issue with the Realtek 8152B, a hub (either FE2.2s (Terminus Tech FE1.1s clone) or HS8836 based) and the Zero. It must be somehow linked to the Realtek 8152B and probably some wiring issue in the hub or the ethernet adapter.
To answer RattusRattus' questions above:
1) I'm seeing the issue on any Raspberry Pi Zero I tried. It just seems like it's not 100% reproducible, but affects a large portion of cold boots.
2) Kind of answered by 1)
3) Tried multiple SD cards.
4) Issue occurs even for a single Pi Zero as in my case.
