ceratophyllum
My rPi is under attack
Mon Nov 19, 2012 1:41 pm
I'm using a r-Pi to monitor my fishtank. Right now I just have a DS18B20 temp. sensor set up and a cron job that probes once an hour. I'm trying to figure out the best way to access this machine away from home.
It is behind a router, so I signed up for a free account from no-ip.com to make my r-Pi visible to the outside world and set my router to forward port 22 from this machine.
Unfortunately, I see loads of stuff like this every day in the /var/log/auth.log:
Nov 18 21:55:01 raspberrypi sshd[3472]: Failed password for root from  61.132.237.9 port 35473 ssh2
Nov 18 21:55:01 raspberrypi sshd[3472]: Received disconnect from 61.132.237.9: 11: Bye Bye [preauth]
Nov 18 21:55:03 raspberrypi sshd[3476]: pam_unix(sshd:auth): authentication      failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.132.237.9  user=root
Nov 18 21:55:05 raspberrypi sshd[3476]: Failed password for root from 61.132.237.9 port 35896 ssh2
This stuff happens every day. Random ports and IP addresses from all over the place.... (eg. whois reports that 61.132.237.9 is someplace in China!)
Is there anything I can do to make this computer less visible or more secure? I'm only running sshd because I want to tinker around in my spare time with the scripts that will probe the sensors when I'm at the office.
Maybe I should just forget about having a permanent domain name, get dropbox write all my fishtank data logs to ~/Dropbox?
I don't know a lot about network security, but I'm starting to get paranoid :D !
Re: My rPi is under attack
Mon Nov 19, 2012 2:10 pm
My Pi isn't visible from external addresses, but one of my Debian PCs is.
On that I run denyhosts, which updates the hosts.deny file when an IP address has x failed login attempts in a defined period.
I also use one time passwords for connecting from outsde (otpw-bin and libpam-otpw) and generate a list of random single-use passwords for each user.
Some people use fail2ban instead of denyhosts.
If your office always shows up as the same IP, you could probably set your router rule to only forward port 22 from that address to your fishtank.
ceratophyllum
Mon Nov 19, 2012 3:19 pm
Well, I decided to try fail2ban just because I found it first.
I'll probably set up one-time passwords as well.
I'm also using DHT22 to sense room temp/humidity and the adafruit "driver"--a c-program that must run as root--only works about 2/3 tries. Maybe an arduino would work better?
I've been considering an arduino with an ethernet shield or Xbee instead of the Pi, but all these "shields" and Xbee doo-dads are really confusing, overly specialized, and expensive compared to a Pi, breadboard, and GPIO cable, and a handful of cheap sensors. (Right now, price of 2 Xbee modules = one rPi, at least.)
I'm curious about Xbee, but the books on it look scary: large sections are devoted to screen shots of some horrid windows serial/USB program full of arcane options. (If Xbee is the craptaculatar version hell it appears at first glance, perhaps the price of Xbee modules will drop and I will get more curious to try them.)
RaTTuS
Mon Nov 19, 2012 3:36 pm
if you don't have the default raspberry name and password set and you only forward 22 80 then your going to be mostly ok.....
just make sure your username / password is not a easy guess ;)
Covfefe
ghans
Mon Nov 19, 2012 4:26 pm
I heard using another port would also easily deter most attacks.
ghans
elatllat
Mon Nov 19, 2012 4:40 pm
using ssh keys (disabling pass auth) is the best solution IMO
SBC with 32GB RAM: https://hardkernel.com
FAQ : https://raspberrypi.stackexchange.com
Unanswered: https://www.raspberrypi.org/forums/search.php?search_id=unanswered
freemanbubu
Mon Nov 19, 2012 6:16 pm
Ports 1 to 1024 are reserved for services like http, ftp, ssh, imap, ....
Hacking bot scan random IPs and try attack on these "defaults" ports...
NAT these port direct from WAN to a computer is totally unsecure....
To avoid this, just NAT another WAN port .
For example, I NAT port 22000 (WAN) to port 22 (Pi)
to connect from WAN, I use my dns name, and port 22000....
Easy and I never see any attack from years on my computers....
Wendo
Wed Nov 21, 2012 4:41 am
Depending on your router/firewall you may also be able to firewall countries. So you could drop connections from everywhere but your home country. Certainly forwarding a different port number will cut down heavily on this
utamav
Fri Jun 20, 2014 12:16 am
Not sure if this has got to do anything but I listed my IP on no-ip to get DDNS. I have been getting brute force login from China as well. Has no-ip's database intentionally or unintentionally been compromised?
binaryhermit
Fri Jun 20, 2014 12:54 am
Probably not... I suspect that the Chinese cracker just port-scanned and is attacking your box because he/she found a ssh server on port 22.
ghans
Fri Jun 20, 2014 8:12 am
Its not that difficult ... AFAIK crackers already portscan whole
countries at a time.
ghans
Fri Jun 20, 2014 1:20 pm
It's not just you. My Ubuntu system blocks about ten attempts per day. I have fail2ban running set for one attempt and you get blocked forever (until the next reboot or fail2ban restart).
I've even blocked myself from a remote location a couple of times.
This is a doctor free zone.
firedrow
Fri Jun 20, 2014 4:18 pm
NO-IP is a popular free DNS service, they could just be scanning NO-IP domains then port scanning those that respond to ping. You could try another free service like DuckDNS or Afraid.org. Also do different port mapping, such as 2222/tcp WAN to 22/tcp LAN (I pretty sure someone said something similar already). SSH Keys is also another good call. Don't use passwords, use SSH Keys to login or do password AND SSH Keys. Then they can try all day long for password cracking.
JAVE
Thu Jun 26, 2014 2:03 pm
The simplest solution is to use another port.
Pick an unused port >1024 (the first 1024 ports are reserved).
For example, pick port 2022.
Edit the /etc/ssh/sshd_config file, and change the line with 'Port 22' to 'Port 2022' (or add that line if it's not there)
While you're there, make sure that 'PermitRootLogin' is set to 'no'
reload the sshd config (/etc/init.d/ssh reload), and you should be able to log in on port 2022 from now on.
You will never want to log in as root. You log in as a regular user. If you must do something as root, su to root, and drop back to the normal user when you're done. (I'm not a fan of sudo. If somebody knows your password, he has root access, if you use a 'normal' set up, a user must know both your password and the root password before he has root access)
Thu Jun 26, 2014 2:11 pm
How does picking an obscure port help? If the crackers do a full port scan they will find that one. Security by obscurity is no security at all.
Preventing password use and having fail2ban monitoring /var/log/auth.log for violations is easier - my system has 22 open with no problems (except when I've blocked my own remote sessions).
HiroProtagonist
Fri Jun 27, 2014 12:29 am
DougieLawson wrote:How does picking an obscure port help? If the crackers do a full port scan they will find that one. Security by obscurity is no security at all.
How does it help? With port 22 open, my system was getting constant root login attempts. Since switching to a different port I've had zero. Evidently failure to do a full port scan is very common.
Disabling password access is a good idea no matter what your setup is.
n3tm4n
Fri Jun 27, 2014 8:03 am
My Internet router is configured to log amongst other things all incoming TCP SYNs (the first step to a TCP handshake) to a syslog server. Whilst other scanning methods are available without using SYN (the RST bit for session reset for example) any TCP session handshake will contain a SYN.
Anyway, what this has demonstrated over the years is that 95%+ of all the port scans my router gets are in the first 1024 TCP ports. I've only had 1 complete scan of ports 1 through 65k in the last 18 months.
If you have to run services, and can move them to an obsecure port then I would recommend it.
Out of interest, some of the ports above 1024 most often scanned on my Internet link are 8080,8888,2222,2323,22222,23232,323232,44300. I can only assume most people pick ports that are not to inventive. :)
HTH. Jon.
http://0x25.blogspot.co.uk/
jojopi
Fri Jun 27, 2014 8:46 am
You are supposing they are human. Of course a human will do a full port scan, review the protocols and services and versions you are running, and consider the best way in. They will be attacking you specifically, for some reason.
But essentially all background SSH noise is from automated attack tools. They cannot do social engineering or use any intelligence to determine likely credentials. They can only try standard usernames and dictionary passwords like "root" and "password1".
They only understand how to attack a specific protocol. (You could probably have a root shell open on a port, and they would not know how to use it.) With billions of addresses to target, it is not worth their time scanning all 65536 ports on the off chance that SSH is on a non-standard port, yet still accepts a standard password.
I have had SSH open on non-standard ports for decades and never seen a single connection.
When there are botnets of tens of millions of machines, blocking their IP addresses one at time seems very unlikely to be useful. If you know you will only connect from specific ranges, then allow only those ranges, otherwise do not worry.
You have never blocked a single attack (presumably, your machines are not vulnerable to password guessing anyway), but you admit you have locked yourself out. And blocking scripts can actually increase the noise in your log files.
rgrbic
Fri Jun 27, 2014 9:39 am
Here you can find some guidelines how to improve security of your RPi.
Change port number, use key pair based authentication and install fail2ban.
At 127.0.0.1
Twitter: @rgrbic
IoT-projects.com
zSprawl
Fri Jul 04, 2014 8:20 pm
A better answer is to setup VPN to your home router, then access your stuff safely. Exposing to the internet is exposing it to attackers all day, every day.
emgi
Sat Jul 05, 2014 7:18 am
Same thing here. For this reason I decided to only have port 80 open.
When checking the logs I'm happy to knowthat I'm not doing anything with php.
The number of attempts involving an assumed weakness in some php script are stunning.
And indeed, it's often the Chinese.
Sometimes I wonder if they are being encouraged somehow to attack the capitalists. :evil:
/emgi
cyrano
Sat Jul 05, 2014 11:07 am
emgi wrote:And indeed, it's often the Chinese.
There is an "official" bounty program for "information". And since official policy is complete denial when it comes to cybercrime every poor person with a little bit of IT knowledge will try getting a part of the bounty. They also carry out information gathering inside China, as long as it is dissidents being spied upon. There is even OSX malware, directed at Tibetan dissidents that was very probably government issued.
Your average Russian, Israeli or NSA hacker, off course, won't be as easily spotted in your logs.
ghans
Sat Jul 05, 2014 11:16 am
Or those guys just mask themselves with Chinese IPs ?
ghans
binaryhermit
Sun Jul 06, 2014 12:50 am
If I had to guess, it's Chinese XP boxes that are part of a botnet either due to dubious DRM cracks or lack of patching.
H2SO4
Wed Jul 09, 2014 10:39 pm
Which explains why the military gave up on that silly camo nonsense and now equips everything with blaze orange.
