Need help with SSL setup for Apache
Posted: Sat Jan 12, 2019 9:29 pm
by jonas740
Hello.
I need help. I am NOT an experienced Linux user so be kind :slight_smile:
I have gotten stuck in trying to configure my SSL for apache.
In this guide: https://doc.owncloud.org/server/10.0/ad ... pache.html 1
I have added the SSLOpenSSLConfCmd DHParameters /etc/apache2/dh4096.pem into my ssl.conf file wich is located in /etc/apache2/mods-enabled/ directory. I hope this is the correct place to add that.
After this the guide wants me to add “/.well-known/acme-challenge” in my Virtual host directive for port 80. But what file contains this directive ? I feel like a noob for not finding this.
Further down the guide they also want me to adopt my virtual host block. Where exactly do i find this ?
Im running Raspbian on my raspberry 3 b+
Googled like a crazy man to find answers but im a bit stuck at the moment.
Please help.
Re: Need help with SSL setup for Apache
Posted: Sun Jan 13, 2019 3:55 pm
by bzt
I don't remember setting up SSLOpenSSLConfCmd, well ever. All you need is a certificate and a private key, and of course an "SSLEngine On" directive: https://httpd.apache.org/docs/2.4/ssl/ssl_howto.html
To generate the keys and the certificate file, you've several options. One is apache2-ssl-certificate. Another one is using OpenSSL. Just for the records, if you don't want a self-signed cert, the steps are exactly the same, it's just you have to send the generated CSR to a CA (plus pay their hilariously overpriced fee) and they will send you back the certfile to be used with SSLCertificateFile. Just a sidenote, you probably don't want to protect your private key with a passphrase, as that would mean every time you restart apache2 you'll be prompted for it.
Cheers,
bzt
