Ibro100
Raspberrypi hang on ssh or vnc on eth0 0
Tue Oct 16, 2018 2:53 am
i do not observe any problem connecting pi to hdmi, mouse and keyboard.
ifconfig eth0 0
dclient br0
or
ip addr flush dev eth0
ip addr add 192.xxx.xxx.5/24 dev br0
ip link set br0 up
ssh or vnc work fine but eth0 0 force me to disconnect the pi from wall socket.
is there anyway this problem can be solve
AnneCreek
Re: Raspberrypi hang on ssh or vnc on eth0 0
Tue Oct 16, 2018 5:10 pm
"ssh or vnc work fine but eth0 0 force me to disconnect the pi from wall socket."
Good way to corrupt your SD!
Can you get to / activate "terminal"? Use "sudo reboot / shutdown" .
Can you use hardware "reset" instead?
Better yet - describe the "hang" AND let's fix the issue first.
Ibro100
Tue Oct 16, 2018 8:47 pm
what i mean is it hang and you cant even reboot or shutdown. is there any way you can help for this
Ibro100
Wed Oct 17, 2018 8:21 am
Actually am running a mesh topology on raspberrys and all the interface interconnected to other raspberrypi i.e eth0, eth1, eth2, eth3, eth4 using usb ethernet adapter. the only way i can i start up an ovs is to ssh into pi eth0. although hang and frozen of the pi persist where Crt C dont even work. i tried other several option sudo ifconfig br0 10.42.0.22 netmask 255.255.255.0 up. still frozen. is there any method available to start up all the interfaces without hanging
