AnneCreek
Setting WiFi static IP
Mon Oct 15, 2018 3:40 pm
I am currently accessing my RPi via SSH , both wired (via Ethernet) and wireless (built-in WiFi).
Been using wired SSH for awhile and really do not recall how the IP got set to be static.
I have the WiFi working , but would like to set the IP as static.
No technical reason , just for convenience. .
Here is a copy of setting static IP I am going to use as an example
static ip_address=192.168.0.10/24
My question is - what is the purpose of "/24" at the IP?
static value
Configures a static value. If you set ip_address then dhcpcd
will not attempt to obtain a lease and just use the value for the
address with an infinite lease time. If you set ip6_address,
dhcpcd will continue auto-configuation as normal.
Here is an example which configures two static address, an IPv4
router, DNS and disables IPv6 auto-configuration. You could also
use the inform6 command here if you wished to obtain more infor-
mation via DHCPv6. For IPv4, you should use the inform ipaddress
option instead of setting a static address.
interface eth0
noipv6rs
static ip6_address=fd51:42f8:caae:d92e::ff/64
static routers=192.168.0.1
static domain_name_servers=192.168.0.1
fd51:42f8:caae:d92e::1
Secondly - my current dhcpcd.con is NOT using "wlan0" as interface "name ".
interface wlx00173ffc9a9c
noipv6
My "raspi-config" is configured to use "wlan0" !
wlan0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 10.0.1.58  netmask 255.255.255.0  broadcast 10.0.1.255
        inet6 fe80::a80d:65ff:fedf:6204  prefixlen 64  scopeid 0x20<link>
        ether aa:0d:65:df:62:04  txqueuelen 1000  (Ethernet)
        RX packets 34  bytes 7175 (7.0 KiB)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 224  bytes 34939 (34.1 KiB)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
Should I be concerned ?
Thanks for reading, help is appreciated. .
B.Goode
Re: Setting WiFi static IP
Mon Oct 15, 2018 3:53 pm
CIDR is the concept to research.
For example: https://www.ipaddressguide.com/cidr
AnneCreek
Mon Oct 15, 2018 4:48 pm
Do I understand correctly "/24" is some kind of "range" ?
Is it optional / can it be omitted ?
So how does it work when I assign SINGLE static IP?
DirkS
Mon Oct 15, 2018 5:18 pm
It's actually the netmask. /24 means 24 bit, which is the same as a netmask of 255.255.255.0
It's basically a more compact way to represent a single (!) network address
dhcpcd5 (which uses /etc/dhcpcd.conf) will assume /24 if you omit it, but it's best to use it anyway.
B.Goode
Mon Oct 15, 2018 7:30 pm
[Original content of this post made redundant by subsequent events, so deleted.]
DirkS
Mon Oct 15, 2018 7:34 pm
It's actually the netmask. /24 means 24 bit, which is the same as a netmask of 255.25.255.0
I think that should be..
"It's actually the netmask. /24 means 24 bit, which is the same as a netmask of 255.255.255.0"
Corrected.
Cheers!
LTolledo
Mon Oct 15, 2018 9:50 pm
If you have access to your router, its better to have it supply a static IP to your devices, whether those are connected via Ethernet LAN cable or via WiFi.
and just leave the network settings on all your devices to get IP automatically via DHCP.
Some people be like:
Greg Erskine
Mon Oct 15, 2018 10:32 pm
+1
Use your router to map MAC to a static IP address.
* Raspberry Pi is a trademark of the Raspberry Pi Foundation
AnneCreek
Mon Oct 15, 2018 11:10 pm
+1
I hope I am making sense , but I like to have permanent IP ( static) for WiFi just like I have for Ethernet.
That way my SSH IP would be always same.
Right now I can access RPi via same Ethernet IP.
But the WiFi IP always changes after reboot.
Technically I do not care, but my crossconnncet complier has to be reconfigured each time WiFi IP changes.
It would be more convenient if the WiFI IP stayed the same.
SurferTim
Mon Oct 15, 2018 11:16 pm
You can set static network settings for a specific ssid, like the one at your home, and get dhcp settings for the rest, like work or school.
In /etc/dhcpcd.conf:
ssid YourSSID
static ip_address=192.168.0.200/24
static domain_name_servers=8.8.8.8
klricks
Mon Oct 15, 2018 11:55 pm
+1
As others have said use the DHCP MAC to IP Reservation feature of your router instead of setting a static config on your RPi.
That way the router will always assign the same IP address of your choice with no changes made on the RPi itself.
Be sure to assign a different IP to each interface Wired and WIFI.
This is handy because you can wipe your SD card and start again or boot a different OS and the network will just work.
Also if you take your RPi to another network it will revert to DHCP mode and work there as well.
jsimmonstx
Wed Oct 17, 2018 4:18 pm
These links might help you set your pi to have a static IP...
https://www.modmypi.com/blog/how-to-giv ... ess-update
https://www.modmypi.com/blog/tutorial-h ... ip-address
You have to work on your google foo... :)
If you want to do it through a GUI, you can try this app:
sudo apt-get -y install wicd
