Ibro100
Access point not working from new update (11-10-2018)
Fri Oct 12, 2018 7:53 am
Did any one noticed that wifi stop working form official documentation https://www.raspberrypi.org/documentati ... s-point.md. No more access point and connection.
Can some help with new configuration.
ShiftPlusOne
Re: Wifi stop working from new update (11-10-2018)
Fri Oct 12, 2018 8:15 am
Is this on-board wifi or are you using a USB device? If it's USB, what's the output of 'lsmod'?
Ibro100
Fri Oct 12, 2018 8:18 am
I mean Hostapd access point from official documentation
SurferTim
Fri Oct 12, 2018 12:24 pm
You didn't answer the question.
You can start troubleshooting by running this from a command line.
sudo service hostapd status
It should display active (running). If it doesn't, you have a problem. If you post what it does return, maybe we could help you.
