dyoung
Local Network Connection Problems
Wed Nov 07, 2012 10:24 pm
Hi-
I just got my Pi (first time using linux) and I'm starting with trying to access an html page. I've created a file called "dogdoor.html" in my /var/www folder that just says:
"<HTML><BODY>The door is closed</BODY></HTML>"
I can see it perfectly when accessing it from http://localhost/doogdoor.html
I used ifconfig to check the IP address of 127.0.0.1, however when I try to access 127.0.0.1/dogdoor.html I get a connection error message. I also cannot see the index page when just pointing to 127.0.0.1.
When I ping 127.0.0.1 everything comes back just fine.
Am I missing something here? I've spent hours looking around on posts and trying things without any success.
Thanks!
dyoung
Re: Local Network Connection Problems
Wed Nov 07, 2012 11:47 pm
Strangely enough, after posting this I thought I'd double check the fundamentals. I booted up the system, ran 'ifconfig', and found a different ip address listed! 192.168.3.127 instead of 127.0.0.3!
I'm not sure if I missed it, or the reboot helped me complete or undo some of my tinkering, but a fella can't argue with results! Upon pointing to the new ip address, things worked as expected.
Thanks!
Wendo
Thu Nov 08, 2012 6:27 am
127.0.0.1 is whats known as the localhost address.
Every single computer with a network stack has that address, so no matter what computer you type it on, you're talking to that computer.
As you've discovered, to access something across a network you need an IP address tied to a network interface other than localhost
