th2000125
mysql database wont work with webserver
Wed Nov 07, 2012 8:49 pm
hi i dont understand whats going wrong with the code but it just wont access the data base i made can somone help me?
<?php
session_start();
$username = $_POST['username'];
$password = $_POST['password'];
if ($username&&$password)
$ connect = mysql_connect("192.168.0.87","root","password") or die ("couldnt connect to database");
mysql_select_db("login") or die ("couldnt find database);
$query = mysql_query("SELECT * FROM users WHERE username='$username'");
$numrows = mysql_num_rows($query);
if ($numrows !=0)
while ($row = mysql_fetch_accoc($query))
$dbusername = $row['username'];
$dbpassword = $row['password'];
if ($username==$dbusername&&$password==$dbpassword)
echo "login succesful. <a href='home.php'">Click here to enter the home page</a>;
$_SESSION['username']=$dbusername;
else
echo "Incorrect password";
else
die ("that username doesnt exist");
else
die ("Please enter a username and password");
System Specs: Processor: AMD FX Bulldozer 6100 Ram: Corsair Vengeance DDR3-RAM 1833 MHz Graphics: SAPPHIRE VAPOR-X HD 7770 GHz Edition OC 1GB GDDR5 Storage: 2TB HDD 64GB SSD 640GB HDD portable.
broo0ose
Re: mysql database wont work with webserver
Wed Nov 07, 2012 9:58 pm
When you are trying to fix problems like this then the log files and error messages are usually the best clue.
Wendo
Thu Nov 08, 2012 6:29 am
But your best bet is to make mysql bind to an external network interface first, since by default it doesn't
Look for skip-networking in mysql's config file
davorin
Thu Nov 08, 2012 6:40 am
Did you try to connect to your database from the shell?
mysql -uusername -ppassword -h host databasename
What does it tell you?
waldo
Thu Nov 08, 2012 4:36 pm
Well, if you posted that code correctly, an extra space character is your problem:
should be
$connect = mysql_connect("192.168.0.87","root","password")
But I agree, you should try command-line mysql and see if you can log in that way. If so, and you still can't access the db with php, then it may be a permissions problem. (CLI mysql user is whatever user you have logged in that terminal window; php user -- assuming you're using apache -- is "www-data".)
th2000125
Sun Nov 11, 2012 11:01 am
it still will not connect to my sql any more ideas guys?
