I've managed to work out setting up wlan0 with the static IP, but I'm not sure how to configure the second adapter.
root@raspberrypi:/Pi# cat /etc/hostapd/hostapd.conf
interface=wlan0
driver=nl80211
ssid=Pi
hw_mode=g
channel=6
wmm_enabled=0
macaddr_acl=0
auth_algs=1
ignore_broadcast_ssid=0
wpa=2
wpa_passphrase=**********
wpa_key_mgmt=WPA-PSK
wpa_pairwise=TKIP
rsn_pairwise=CCMP
root@raspberrypi:/Pi# cat /etc/dnsmasq.conf
interface=wlan0
dhcp-range=192.168.4.2,192.168.4.20,255.255.255.0,24h
root@raspberrypi:/Pi# grep -C5 wlan0 /etc/dhcpcd.conf
# fallback to static profile on eth0
#interface eth0
#fallback static_eth0
interface wlan0
static ip_address=192.168.4.1/24
nohook wpa_supplicant
denyinterfaces wlan1
root@raspberrypi:/Pi# cat /etc/network/interfaces
# interfaces(5) file used by ifup(8) and ifdown(8)
# Please note that this file is written to be used with dhcpcd
# For static IP, consult /etc/dhcpcd.conf and 'man dhcpcd.conf'
# Include files from /etc/network/interfaces.d:
source-directory /etc/network/interfaces.d
root@raspberrypi:/Pi# cat /etc/wpa_supplicant/wpa_supplicant.conf
country=US
network={
ssid="*****"
psk=*********************************************************************
key_mgmt=WPA-PSK
