Khov
AVAHI Daemon doesn't work
Thu Aug 02, 2018 8:38 am
I have installed lighttpd on my RPI 3 :
sudo apt-get install lighttpd
I have managed to access the web server from /home/pi/www
And it works, I can find my Hello World when I entered 192.168.2.31 in my URL browser.
Now I try to access my raspberry pi through mDns. In this way I have installed AVAHI :
sudo apt-get install avahi-daemon libavahi-client-dev
I have modified my hostname :
Sudo raspi-config
and then select Network option then select Hostname then I have called it myraspberrypi
I have updated my reboot system :
sudo update-rc.d avahi-daemon defaults
Now I try to access my web server from my browser by typing myraspberrypi.local but nothing happen.
Some tutorials use AVAHI to get acces on the RPI through SSH. I tried to access my RPI via SSH with myraspberrypi.local, but nothing...
Ok I do things wrong, but where ??
Thank you for your help
mattmiller
Re: AVAHI Daemon doesn't work
Thu Aug 02, 2018 8:43 am
1. avahi is already pre-installed so need to to install it
2. If your trying to access from a Windows 10 machine, a recent update to Win 10 a few months ago broke mDNS so that is why it doesn't work
Khov
Thu Aug 02, 2018 5:21 pm
Thank you for your answer.
I have activated the hotspot of my smartphone (OS Android) to connect both my RPI and my cellphone on the same wlan0. When I enter the IP of my RPI in the browser of my cellphone, I can see the Hello World message.
But when I use myraspberrypi.local in the url of the browser, it doesn't show anything.... I'm not sure the problem comes only from Windows 10
Khov
Thu Aug 02, 2018 5:35 pm
Same form my RPI itself, when I type myraspberrypi.local in the browser nothing...
mattmiller
Thu Aug 02, 2018 8:10 pm
Did you type in http://myraspberrypi.local
(and try it without the .local e.g http://myraspberrypi )
mattmiller
Thu Aug 02, 2018 8:19 pm
I'm wondering if MS have fixed mDNS recently as I just setup a web server on my Pi and I could access it using http://27Jun18 (The hostname is the release date of the version of Stretch I'm using)
And I can access my Pi over SMB as well using \\s27Jun18\pi
Glad you posted - you've helped me out :)
Khov
Tue Aug 07, 2018 9:46 am
But it doesn't help me :(
mattmiller
Tue Aug 07, 2018 9:28 pm
Hasn't helped me either - using hostnames has stopped working again :(
Khov
Wed Aug 08, 2018 8:02 am
And nobody seems to get a solution for us !
mattmiller
Thu Aug 16, 2018 7:52 pm
I had a Windows update yesterday
At the moment, I can talk to my Pi using hostnames
I'll report back if its still working in a few days time
mattmiller
Thu Aug 16, 2018 7:55 pm
Its working with SMB, web pages and VNC
mattmiller
Fri Aug 17, 2018 8:38 pm
Just tried to use file manger to look at files on another pi using hostname today - worked fine
So either I am being very lucky over past couple of days or MS have fixed their mDNS issues
mattmiller
Thu Aug 23, 2018 9:05 am
Turns out I was being lucky - still not reliable :(
