edwardzion
SSH not working in new raspbian-first-time-install
Sat Jul 14, 2018 2:50 pm
Hey guys, Yesterday my pi was working well. I was using my pi via ssh in my laptop. This morning I tried to connect but there was an error(connection timeout). So, what I did was took a new SD card and installed a fresh version of raspbian onto it. I enabled ssh in by adding a file named ssh with no extensions. But, the problem still persists. I tried fixing it again and again. I also connected the pi to a screen to check if ssh was enabled and it was already enabled. It was bugging me all day :x . It seems like a hardware issue :oops: . I need to use ssh for a school project and I can't carry around a screen. Any fixes? :idea: ? :?:
pcmanbob
Re: SSH not working in new raspbian-first-time-install
Sat Jul 14, 2018 3:12 pm
Hi.
Are you sure you are using the correct IP address to connect to your pi.
while you have the screen /keyboard attached to the pi check its IP address.
Remember we want information.......................no information no help
The use of crystal balls & mind reading is not supported
HawaiianPi
Sat Jul 14, 2018 5:19 pm
Which model Pi?
How are you connecting the Pi to a network?
How did you find your Pi's IP address?
And is your laptop on the same network?
Or are you trying to connect in a different way (like Pi Zero USB Gadget mode or direct Ethernet)?
I have tested the latest version of Raspbian Lite on my Pi0W and it worked as expected. I just added the ssh file and a pre-configured wpa_supplicant.conf to the "boot" partition of a freshly imaged card and booted it up. The Pi0W connected to my router with SSH enabled, and I was able to SSH in after finding the correct IP in my router's client table.
edwardzion
Sun Jul 15, 2018 8:03 am
Which model Pi?
I am using Raspberry pi 3 B+. I found my pi's IP address using advance IP scanner. I am trying to connect via putty and my laptop is on the same network. The pi is directly connected to my laptop via Ethernet. "raspberrypi.mshome.net" was shown as a dead network.
Sun Jul 15, 2018 8:08 am
Have you enabled ssh?
Create a /boot/ssh file (sudo touch /boot/ssh or sudo touch /boot/ssh.txt) then reboot. Or use sudo systemctl enable ssh; sudo systemctl start ssh.
Note:Having anything remotely humorous in your signature is completely banned on this forum.
edwardzion
Sun Jul 15, 2018 8:21 am
Yes Sir. I enabled ssh. Yet I am not able to connect.
pcmanbob
Sun Jul 15, 2018 8:51 am
Did you check your are using the correct IP in your attempt to connect to the pi ?
Can you ping the pi from your pc ?
edwardzion
Sun Jul 15, 2018 9:18 am
I am using the correct IP.
PhatFil
Sun Jul 15, 2018 11:03 am
straw clutching time,
have you tried disabling any firewall s/w on your client computer before attempting a connection ? a careless dismissal of a message box could have resulted in a blocking rule??
what client tool are you attempting to connect with? how is it configured? a quick check of my Putty terminal reminded me ssh traffic is expected over port 22..
edwardzion
Sun Jul 15, 2018 2:04 pm
I tried disabling the firewall and it worked!! Thank you very much. Your help is appreciated :D :D :D
PhatFil
Sun Jul 15, 2018 6:49 pm
Ha it was bound to work sometime.... now to correct the rule blocking access..
