Samsquanch
Re: HOWTO - Using Raspberry Pi 3+ as Plex Media Server
Sun Feb 17, 2019 3:12 pm
Disregard that last comment I posted.
I got the server to start working. But now it can't find my files on my hard drive. Plex can see my hard drive, but it can't see any of the files in it. Including the file names (movies, tv shows ect). When I manually put in the file I want to scan, it just says "there are no items in this library".
But if I go into file manager, I can see everything as well as play the content right on the video player on pi.
What could be the problem.
MaxTheSpy
Sun Feb 17, 2019 7:48 pm
I apologize for the confusion, and that I wasn't able to reply faster, Please look at troubleshooting 1. It will walk you through how to make the plex recognize your files.
Ask Me About:
Plex Media Server (PMS)
RasPlex
dansholy
Wed Feb 27, 2019 11:19 pm
I got a movie to play on the sd card but when I search library on the external nothing shows.
The external drive has read only permissions and i have zero knowledge of linux.
I believe the device is extended
wentle
Fri May 17, 2019 7:54 pm
I am following your install thread and keep having issues when it comes to installing plexmediaserver. I'm running Raspbian on a desktop and just set it up. When I go to execute the command, this is my response any help is appreciated. FYI I'm still wet behind the ears to computers!
[email protected]:~ $ sudo apt-get install -t stretch plexmediaserver-installer -y
Reading package lists… Done
Building dependency tree
Reading state information… Done
E: Unable to locate package plexmediaserver-installer
ErrorMsg404
Tue May 21, 2019 8:42 am
I'm also having an issue, might be related to wentles but not sure.
Whenever I try to install Plex via the sudo apt-get install -t jessie plexmediaserver command I get this.
[email protected]:~ $ sudo apt-get install -t jessie plexmediaserver
Loading package list... Done
E: Value »jessie« is void for APT::Default-Release such a release is not avalible in the source
Might've mistranslated something but I hope that gets the jist of it.
dantheman84
Tue May 21, 2019 5:39 pm
I am having the same error message and don't see how to troubleshoot this in the guide. Have you tried
sudo apt-get update -y && apt-get install -t jessie plexmediaserver
ErrorMsg404
Mon Jun 03, 2019 8:58 am
I have not but the I think I just had copy pasted it wrong or something? I believe it was this part i messed up.
wget -O - https://dev2day.de/pms/dev2day-pms.gpg.key | sudo apt-key add -
echo "deb https://dev2day.de/pms/ jessie main" | sudo tee /etc/apt/sources.list.d/pms.list
Although I got past that I've now hit another wall that is when I come to the part where you have to restart the pi it won't boot up completely. I get to a point where the screen will be black with a flashing dash in the upper left cornor and it doesn't get further than that.
CrypticOne
Sun Jun 16, 2019 1:41 am
Last time I pulled an update there was a message that dev2day was no longer going to be updating the installer and to switch to the official plex installer.
If you are trying to install now you should ignore the dev2day items and look at the notes below.
Finally, official ARMv7 and ARMv8 Plex packages are available:
https://www.plex.tv/media-server-downloads/ 51
The repo on dev2day.de 8 has nearly reached its end of life. Please
upgrade to the official packages as soon as possible. This repository
will disappear sometime in the future.
The migration is simple and your Plex library will be preserved.
First, remove the dev2day.de 8 package:
sudo apt-get remove plexmediaserver-installer
Then, remove the dev2day.de 8 repo, e.g. with:
sudo rm /etc/apt/sources.list.d/pms.list
Now, download and install the package from plex.tv 4, e.g.:
sudo dpkg -i plexmediaserver_1.15.1.791-8bec0f76c_armhf.deb
Also, an official Plex repository should be available soon:
https://support.plex.tv/articles/235974 ... ributions/ 135
ErrorMsg404
Mon Jun 24, 2019 9:15 am
So I assume I just have to download from the first link yeah? Because when I do and pick Linux > Ubunto/Debian Armv8 and try to run it it fails. That is without doing any of the steps in this guide apart from sudo apt-get update > upgrade.
mejriou
Mon Jul 01, 2019 5:52 pm
What about setting with MacOs?
shefalex
Fri Jul 12, 2019 4:02 pm
Simplest way to install now that I'm aware of:
1/ Add key to apt
wget -q https://downloads.plex.tv/plex-keys/PlexSign.key -O - | sudo apt-key add -
2/ Add source
echo "deb https://downloads.plex.tv/repo/deb/ public main" | sudo tee /etc/apt/sources.list.d/plexmediaserver.list
3/ Update sources
sudo apt-get update
4/ Install
sudo apt-get install plexmediaserver
Server should then be accessible at http://localhost:32400/web
MaxTheSpy
Thu Oct 10, 2019 1:33 am
Samsquanch wrote:
Sun Feb 17, 2019 2:09 pm
Step 9 confuses me. Where/when do I type that stuff in? Could you provide a screen shot explaining exactly where I type it in?
So for step 9 open up your terminal type in hostname -I this will bring up your IP address. Write down the IP address and then enter sudo nano /boot/cmdline.txt into the terminal, this should open up the cmdline.txt file. scroll down to the end of that text file and type this in ip=. After the = sign type in your ip address. Here is an example ip=123.456.789
After that save and exit out of the cmdline.txt and then continue to step 7.
I apologies for the long wait, I am currently working on many other projects.
Ask Me About:
RasPlex
hydra3333
Sat Nov 16, 2019 9:07 am
Simplest way to install now that I'm aware of ...
Thanks, shefalex !
It appears to be consistent with Plex website instructions here : https://support.plex.tv/articles/235974 ... 1573883378
I'm told it's the ARM v7 (NOT v8) which applies to 32bit Raspbian ?
I suppose this applies:
To decide whether you need the ARMv7 or the ARMv8 package, just run this command on your device in a terminal: dpkg --print-architecture and it will tell you, armhf requires the ARMv7 package and arm64 the ARMv8 one.
which is from the older instructions https://forums.plex.tv/t/read-me-first- ... ian/226567
