croisebeck
Network boot raspberry pi 3 help, dont working for me!
Thu May 17, 2018 9:15 pm
Hello, i'am have difficulty for network boot with raspian streech.
Hello, I'm having trouble running the boot from the net following this tutorial:
https://www.raspberrypi.org/documentat ... utorial.md
all steps have been successfully completed although ip is not assigned when I connect raspberry pi 3 (client) and not boot from the network ...
my router dhcp It's off.
Has anyone else done this tutorial yet?
Thank you!
aaronouthier
Re: Network boot raspberry pi 3 help, dont working for me!
Thu Jun 21, 2018 4:59 am
croisebeck wrote: all steps have been successfully completed although ip is not assigned when I connect raspberry pi 3 (client) and not boot from the network ...
This is like trying to make your head stop hurting, by hitting it with a hammer...
If you don't have a DHCP server somewhere on your network, then your Pi will never get a IP address. Either manually assign the Pi a static IP, or re-enable the router's DHCP server.
croisebeck
Fri Jun 22, 2018 7:34 pm
OK I understand!
however in the tutorial, I understood that the raspberry pi Server will be the one responsible for distributing the correct IPs? I also do not know if just connecting a raspberry pi client (no memory card) it should receive an IP, or before it is booted over the network.
I have already re-done this https://blockdev.io/network-booting-a-raspberry-pi-3/and now I have re-zeroed the official tutorial, and it does not start the client.
in the
'tail -F /var/log/daemon.log'
You should see something like this:
'raspberrypi dnsmasq-tftp [1903]: file /tftpboot/bootcode.bin not found'
no message on bootcode.bin just that tftpboot has root / tftpboot
I'm not banging my head with a hammer! but she's hurting a lot :(
thank's very much
Who is online
Users browsing this forum: pws and 10 guests
