MultiVariableMaestro
OpenVPN on Raspberry Pi 3+
Tue May 15, 2018 5:23 pm
I followed this guide: https://readwrite.com/2014/04/10/raspbe ... -browsing/
As I proceeded, I encountered a few errors that i was able to resolve, but there was one issue i was no able to solve. If you look on the guide you'll find the section where it says to edit the interfaces file. The contents of my interface file differ from what this guide shows. I was able to find out that that is a result of differing versions of Raspbian. This is where i am stuck. I tried to put the code that was intended for the Interfaces file into the dhcpcd.conf. As you can assume, no success. I have some experience, but no where near enough to properly troubleshoot this. If anyone has any suggestions, or a maybe a different method i could follow, it would be greatly appreciated. I'll upload my logs and config files when i get home.
default_user8
Re: OpenVPN on Raspberry Pi 3+
Wed May 16, 2018 3:34 am
Two heads are better than one, unless one's a goat head.
