gromgsxr
pi 3 b+ smb
Sat Mar 31, 2018 1:37 pm
i have a new pi set up as a smb server with a 1tb usb drive. when ever i try to copy larger files off it it fails, the problem only happens when the pi is connected via ethernet, if the pi is connected to wifi with the ethernet un-connected it works fine. i have used the same setup on a pi 3 for about a year with no issues so it seems specific to the new ethernet hardware which is the whole reason for me getting the newer board.
drgeoff
Re: pi 3 b+ smb
Sat Mar 31, 2018 3:13 pm
Maybe the discussion at viewtopic.php?f=63&t=208512 is relevant.
gromgsxr
Re: pi 3 b+ smb
Sun Apr 01, 2018 2:09 pm
may well be the same i seem to get ok speed about 210 up and 300 down but the connection is not stable and fails if trying to copy larger files. capping the lan speed to 100mb makes it a bit better but its still iffy and a step back from a normal pi3 what a shame i now have a useless paperweight
Re: pi 3 b+ smb
Sun Apr 01, 2018 4:00 pm
We currently have an issue with large file transfers, which we are looking in to. It seems to be network related, ie depends on what sort of devices are being used to manage the network, which is why we haven't picked it up before - all our testing worked!
Have you tried adding the following line to config.txt?
dtparam=eee=off
gromgsxr
Re: pi 3 b+ smb
Sun Apr 01, 2018 4:11 pm
yeah that didn't help it slowed the transfer speed down and was still not able to copy large files it would still fail part way through
Re: pi 3 b+ smb
Sun Apr 01, 2018 6:29 pm
eee should have no effect whatsoever on transfer speed. So that's a bit odd.
gawkmeister
Re: pi 3 b+ smb
Mon Apr 30, 2018 4:13 pm
I think I'm seeing this or a related issue.
Raspberry Pi 3 B+ --- Kernel 4.14.34-v7+ #1110 SMP Mon Apr 16 15:18:51 BST
Wired Ethernet, 8TB disk on USB, Samba
Attempting to transfer a large repository from Windows 10, using Backvp2
When the backup program attempts to transfer a large file (over 80MB or so) the transfer freezes up, but so does all other network communication. A minute or two later my terminal windows will close and I'm able to reconnect. Once reconnected, I cannot see anything in /var/log that suggests what might have happened.
I have not yet tried switched to WiFi on the Pi.
Any thoughts ?
gawkmeister
Re: pi 3 b+ smb
Mon May 07, 2018 7:09 pm
I reported in the 'lockup' thread that switching to Wifi seemed to get around the problem with the ethernet freezing, but then I ran smack into the other problem and the Pi crashed completely after a couple of hours of the samba job.
So today, I made a trip to my vendor and he replaced the Pi 3B+.
Unfortunately, this one seems to behave just like the last one, at least so far. The ethernet froze up after a few minutes of samba traffic.
gawkmeister
Re: pi 3 b+ smb
Tue May 08, 2018 10:14 am
I think I'm talking to myself in this thread, but ...
I applied the rpi-update recommended by jamesh in the lockups thread. The ethernet no longer freezes on samba transfers and the Pi stayed up working through the night.
No sure what the firmware update did ... but it seems to be the right thing for the problems I was seeing.
gromgsxr
Re: pi 3 b+ smb
Wed May 09, 2018 6:48 pm
can you post a link to the lock up thread you were on about? my 3b+ has actually been retied and is just gathering dust on my table as last time i checked it was un useable
gromgsxr
Re: pi 3 b+ smb
Fri May 11, 2018 5:48 pm
i have to say it is better after the update but it still not completely fixed, i was testing it and every so often a transfer fails when it fails i can use a second computer and still copy files off the pi but the computer the transfer fails on can no longer copy any more files until the pi is rebooted
FezVrasta
Re: pi 3 b+ smb
Sat May 19, 2018 7:39 pm
same here, the update helped but it's not completely fixed.
gromgsxr
Re: pi 3 b+ smb
Tue May 22, 2018 6:17 pm
yeah my 3b+ is still pretty much useless for what i wanted to do with it and is gathering dust again what a shame
