crazycat36
Wireguard server on Raspberry Pi
Thu Feb 08, 2018 7:58 am
I was wondering if there is any way to set up a raspberry pi to act as a VPN server with wireguard support? I was hoping for a link to a detailed set-up guide. Any help on the subject would be much appreciated. Thanks in advance.
Re: Wireguard server on Raspberry Pi
Thu Feb 08, 2018 1:12 pm
How about the wireguard documentation:
Installation : https://www.wireguard.com/install/
No raspberry pi package there but follow option b) and build it from source. They seem to have it running on a ton of other platforms so I'm confident it builds for raspbian.
Configuration: https://www.wireguard.com/quickstart/ They claim "easiest to use, and simplest VPN solution in the industry." So your trying that will be a good test of that claim.
Thanks for the heads up on wireguard. Looks promising.
1PoP
Tue Aug 07, 2018 10:58 am
Doesn't work for me after setup:
pi@thepi:~$ ip link add dev wg0 type wireguard
RTNETLINK answers: Operation not permitted
lwahonen
Tue Aug 07, 2018 9:18 pm
You need to use have root powers to edit network settings, e.g. sudo ip link add dev wg0 type wireguard
Cheers,
will
WillBerriss
Sun May 19, 2019 3:24 pm
Note that to install the linux headers, the following suggested command won't work:
sudo apt-get install linux-headers-$(uname -r)
Instead of that you need to do the following:
sudo apt-get install raspberrypi-kernel-headers
DarrenHill
Sat May 25, 2019 4:51 pm
DietPi now has various server options with easy install, including Wireguard.
Set mine up a few weeks ago and working very well.
beta-tester
Sat Jun 29, 2019 1:00 pm
you told, Wireguard is included to DiretPi.
i just installed the DietPi image to my RPi, but i can not find Wireguard to install...
how did you installed it?
the image is DietPi v6.24.1
i only can see OpenVPN, PiVPN, DietPi-NordVPN to install in DietPi-Software|VPN
RPi B (256MB), B (512MB), B+, ZeroW; 2B; 3B, 3B+; 4B (4GB)
DarrenHill
Sat Jun 29, 2019 1:41 pm
https://dietpi.com/phpbb/viewtopic.php?p=16308#p16308
For me it's item 172, at the bottom of the VPN list in dietpi-software.
This is under DietPi v6.24.1 : 14:43 - Sat 29/06/19
beta-tester
Sat Jun 29, 2019 5:33 pm
i don't get it... i have the same image version as you.
but i don't have item 172 . item 171 is DietPi-NordVPN and 173 is something for the desktop or so...
but 172 does not existing on my list.
in case i am not up to date,i made
apt full-upgrade
is it possibly because i am using a RPi1B rev.2 at the moment... ?
beta-tester
Sun Jun 30, 2019 5:45 am
yes it is... it is only available for CPUs with ARMv7 and higher:
see WireGuard not running on RPi 1 #2474
but you can compile and install WireGuard easely by hand:
see Install WireGuard on Raspberry Pi 1, 2 (not v1.2), Zero, Zero W
DarrenHill
Sun Jun 30, 2019 8:57 am
It all fits yes - mine's on a 3B.
harrypnyce
Mon Jul 01, 2019 10:46 pm
I messed things up by installing Wireguard PRIOR to upgrading the linux-kernel-headers and now cannot seem to recover from this little dilemma. :oops: Any suggestions?
raspberrypi-kernel-headers is already the newest version (1.20190620+1-1).
modprobe wireguard fails with the following message:
modprobe: FATAL: Module wireguard not found in directory /lib/modules/4.19.56-v7+
Running Raspbian GNU/Linux 10 Lite (buster) on a RPi3B+ with Linux kernel 4.19.56-v7+ -- all of my /lib/modules/ appear in the 4.19.50-v7+ folder, which has a symbolic link:
/lib/modules/4.19.50-v7+/build -> /usr/src/linux-headers-4.19.50-v7+
DarrenHill
Tue Jul 02, 2019 10:49 am
Try
dpkg-reconfigure wireguard-dkms
(from the DietPi documentation post on WireGuard here, the NB comment at the bottom).
