crazycat36
Wireguard server on Raspberry Pi
Thu Feb 08, 2018 7:58 am
I was wondering if there is any way to set up a raspberry pi to act as a VPN server with wireguard support? I was hoping for a link to a detailed set-up guide. Any help on the subject would be much appreciated. Thanks in advance.
Re: Wireguard server on Raspberry Pi
Thu Feb 08, 2018 1:12 pm
How about the wireguard documentation:
Installation : https://www.wireguard.com/install/
No raspberry pi package there but follow option b) and build it from source. They seem to have it running on a ton of other platforms so I'm confident it builds for raspbian.
Configuration: https://www.wireguard.com/quickstart/ They claim "easiest to use, and simplest VPN solution in the industry." So your trying that will be a good test of that claim.
Thanks for the heads up on wireguard. Looks promising.
1PoP
Tue Aug 07, 2018 10:58 am
Doesn't work for me after setup:
[email protected]:~$ ip link add dev wg0 type wireguard
RTNETLINK answers: Operation not permitted
lwahonen
Tue Aug 07, 2018 9:18 pm
You need to use have root powers to edit network settings, e.g. sudo ip link add dev wg0 type wireguard
Cheers,
will
WillBerriss
Sun May 19, 2019 3:24 pm
Note that to install the linux headers, the following suggested command won't work:
sudo apt-get install linux-headers-$(uname -r)
Instead of that you need to do the following:
sudo apt-get install raspberrypi-kernel-headers
DarrenHill
Sat May 25, 2019 4:51 pm
DietPi now has various server options with easy install, including Wireguard.
Set mine up a few weeks ago and working very well.
