randloki
VPN OpenVPN ovpn Windscribe for stretch
Sat Jan 06, 2018 1:08 am
It took me awhile and looking at multiple different forums and websites to get my windscribe vpn to work on my pi 3b Stretch Raspbian OS. I have tried this on several fresh installs and updates on stretch. I hope someone finds it useful.
Windscribe Raspberry Pi Stretch latest version 1/4/18
Download Credentials from Windscribe. Save copies to downloads or desktop.
STEP 1. Get your current package list updated:
$ sudo apt-get update
STEP 2. Install the openvpn daemon/package:
$ sudo apt-get install openvpn
STEP 3. Download the needed config files and then copy them to the pi (via scp or FTP), then unzip them into /etc/openvpn (I just downloaded mine right to the pi or used vnc from my laptop)
(your OVPN File such as : Windscribe-US-Germany.ovpn)
$ sudo mv Windscribe-US-Germany.ovpn /etc/openvpn
$ cd /etc/openvpn
STEP 4. Make the up/down script executable
sudo chmod +x /etc/openvpn/update-resolv-conf
STEP 5. Use the following command to get connected (replace config file with the one of the VPN server you want to connect to):
sudo openvpn --daemon --cd /etc/openvpn --config Windscribe-US-Germany.ovpn
#put your vpn config file name exactly as it is in pi.
put in username:
put in password:
(both given on windscribe site).
Check status:
Type: $ curl ipinfo.io/ip
STEP 6. To disconnect run:
$ killall -9 openvpn
Option 1. Enable VPN at boot
sudo systemctl enable openvpn@Windscribe-US-Germany.ovpn
Anything not covered please reffer to manual
$ openvpn --help
I am fairly new to linux so I hope I can attribute to the next man as much as the community has helped me. Any suggestions or comments let me know. I may update this is anyone has anything further to contribute.
brianinmaine
Re: VPN OpenVPN ovpn Windscribe for stretch
Mon Feb 12, 2018 4:50 am
I also use Windscribe and just spent many hours trying to configure my setup just as I wanted.
I use a no-ip ddns address on my (Belkin)router with 1 port open for ssh.
My goal was to have the VPN up all the time, but still be able to ssh into the pi through my ddns address so I could tunnel other ports through that.
I came up with a very IN-elegant?? way to do that: I created a script I call /etc/openvpn/onstart:
#!/bin/bash
sleep 5
ip rule add fwmark 65 table novpn
ip route add default via 192.168.2.1 dev wlan0 table novpn
ip route flush cache
iptables -t mangle -A OUTPUT -p tcp --sport 22 -j MARK --set-mark 65
and I call it with a service file (/etc/systemd/system/VPNrules.service)
[unit]
Description=VPN rules
Wants=network.target
[Service]
ExecStart=/etc/openvpn/onstart
StandardOutput=syslog
StandardError=syslog
SyslogIdentifier=onstart
User=root
Group=root
Restart=always
[Install]
WantedBy=multi-user.target
after starting, enabling, and rebooting, this all seems to work out for me. I can sftp into the pi, all my regular traffic uses the vpn and I can still ssh tunnel ports, like for qbittorrent-nox...
I did check for dns leaks - seems good. Any advice or suggestions are most welcome?
Good luck!
