Use Pi to use intenetconnection at home from work
Posted: Sun Oct 08, 2017 10:37 am
by klettervirus
Sorry if my question is trivial or stupid, I am missing the right network-related vocabulary to make use of google. So maybe you can give me a head start about where to look.
Here is what I like to accomplish: I want a pi in my home network, that can be reached from the "internet" at work. There access to webmailers is blocked, so I thought I can use the pi to tunnel requests from work to gmx and back for example.
Is that possible, what software would I use and is it possible to make it "sort of" secure, knowing that absolute security does not exist?
Any idea is welcome, thank you for your time and patience, Stefan
Re: Use Pi to use intenetconnection at home from work
Posted: Sun Oct 08, 2017 10:44 am
by rpdom
What you're probably looking for is a VPN (Virtual Private Network) where you can tunnel out to your home network. OpenVPN is one bit of software that does this. I use that for accessing the work private network from home, or my home private network from work. It takes a bit of setting up, but there are many tutorials out there (make sure they are recent ones, much information is out of date).
I also use tinc for a VPN, but that's a bit more specialised.
Posted: Sun Oct 08, 2017 10:45 am
by DougieLawson
OpenVPN does that stuff. Or if it's just screen sharing the RealVNC allows you to access your RPi remotely.
But, watch out as you may be violating your companies acceptable use policy and that could get you a P45 and a chance to look for a new job.
It may be better to get a MiFi cell phone dongle and use that to access the public internet for your personal use.
My wife's http://www.three.co.uk/Store/Mobile_Broadband that I've "borrowed" (permanently) is the most useful thing I've got in my collection of tools and stuff in my laptop rucksack.
Posted: Sun Oct 08, 2017 11:17 am
by klettervirus
Awesome, that helps me hetting started. As for the legal issues, I am aware of those, will ask my boss first :lol:
Thank you very much!
Posted: Thu Oct 12, 2017 4:15 am
by HiroProtagonist
You can do this by installing an http proxy [such as squid] on your pi, & setting up your home router port forwarding to forward to the ssh port on the pi. If your router provides the option, forward a different incoming port to the ssh port on the pi.
Once you can ssh into your pi from work, you can use ssh port fowarding to forward a local port on your work machine to the proxy port on your pi, then you just configure your browser to use the locally forwarded port as the http proxy. This will be securely forwarded to your pi.
Much simpler to achieve if your work machine runs linux. Should also be possible on other OSes with varying levels of pain.
You'll need a way to get to your home IP from work - dynamic dns will help there.
Outgoing ssh could also be firewalled at your workplace.
