Aravind_Raj
Is it any possible to convert analog phone to IP phone using Raspberry PI
Thu Sep 14, 2017 11:47 am
I need IP Phone for VOIP purpose. I have Raspberry PI and analog phone. Is there any possibility for interfacing analog phone with Raspberry PI.
RaTTuS
Re: Is it any possible to convert analog phone to IP phone using Raspberry PI
Thu Sep 14, 2017 11:51 am
not easily , it will need extra hardware
Covfefe
Thu Sep 14, 2017 12:02 pm
Much easier to either buy a dedicated IP phone, or get an app for your PC/mobile or maybe Pi that will turn it into an IP phone. I use Linphone on my Linux PC, Zoiper on my Adnroid mobile and a proper hardware IP phone as well.
Aravind_Raj
Thu Sep 14, 2017 12:18 pm
Your idea is a good one but I can't attend the call via head phone. I need to ring the analog phone. Is possible to connect buzzer with RPI.
Thu Sep 14, 2017 12:41 pm
I use a Yealink T46G for my main IP phone, but then I do work for a telecoms company that supports VoIP and need that phone when I am working from home.
The mobile apps (Zoiper, Bria and others) just work on your mobile phone like using it for normal calls. PC apps like Linphone can be used with internal microphone and speakers or a headset (actually headset is better on those), or the dedicated hardware phones are just like normal phones. Pick up handset and dial or answer (I usually use a bluetooth headset on mine).
Are you looking to use a VoIP provider, or an ordinary telephone line? To use IP you need an IP connection.
ghans
Thu Sep 14, 2017 12:52 pm
The hardware you need is called "FXO adaptor". They cost at least as much as a Pi , so you could buy them for your PC directly anyway ...
ghans
drgeoff
Thu Sep 14, 2017 1:03 pm
ghans
You need an ATA (Analogue Telephone Adaptor).
It needs to have a FXS port. S is for station ie a phone
A FXO port connects to a telco line (POTS/PSTN). O is for Office, the US term for what the UK calls a telephone exchange.
Ports on ATAs are named by what they connect to.
eg http://www.obihai.com/docs/OBi200DS.pdf ($50 Amazon US. £40 Amazon UK)
hippy
Thu Sep 14, 2017 1:59 pm
I would also suggest that, for most people, a dedicated VOIP phone which just plugs into the router, or a unit which sits between the router and an analogue phone, will be much easier and probably cheaper than trying to get an analogue phone connected to a Pi and used for VOIP.
Thu Sep 14, 2017 4:38 pm
I would add to that if you are using DECT phones you can get a VoIP base station which will allow you to use your existing handsets over a VoIP connection. Some even have a dual PSTN and VoIP capability.
