How to fine tune a Website
Posted: Tue Aug 22, 2017 10:57 pm
by Trigo
Finally i've made it, the website is now online :) (yupi)! But i think that it is a bit slow, my question is how can i manage to get it go faster?
Re: How to fine tune a Website
Posted: Wed Aug 23, 2017 8:16 am
by scotty101
Many browsers come with "Developer Tools". You can use these to see why the website is slow, either in downloading media or script performance. Once you've identified what is slow, you can look at ways to speed it up.
For example, if you use the "Network" tab on the Chrome developer tools, you might find that one particular image is slow to download. You could then modify the image to reduce the size so that it is quicker to download.
Posted: Wed Aug 23, 2017 8:51 am
by Trigo
I've got another issue! I can access it outside of my internal lan, if i connect the phone over 4g i can access it! but if i try to view it's content on my PC it doesn't show a thing! How can i edit it's content?
Posted: Wed Aug 23, 2017 9:02 am
by topguy
Since I dont feel like searching trough all your previous posts to try to figure out what/how your site is set up, maybe you can include this inormation in this thread.
Posted: Wed Aug 23, 2017 9:44 am
by Trigo
Well, the configuration files of the webserver are the same (default ones), as well as the hostnames and so on.... The only thing that i've made to make it go online was creating a hostname with noip, inserting the hostname on the router (Huawei), open port 80 and that's it! It is online! Now the only thing that i'm not able to do is to view and edit it's content when inserting the hostname on the browser!
by elmapache
  • Use Nginx instead of Apache
  • Install Raspbian into a fast USB drive instead of the MicroSD card
  • Use MariaDB instead of MySQL
  • Use Redis.io if your application supports it to cache the database queries
  • Set up the PHP caches
  • Use minimalist semantic markup (check CutCodeDown)
  • Optimize your application
Posted: Wed Aug 23, 2017 9:53 am
by Trigo
you are not helping, thanks anyway!
Posted: Wed Aug 23, 2017 12:33 pm
by drgeoff
Many routers do not permit you to access a server on the same LAN by using the public IP. Search for 'NAT hairpinning' if you want to know more.
Try using the LAN address (private dotted quad) of the server to access from your editing PC.
Posted: Wed Aug 23, 2017 1:12 pm
by klricks
What is your ISP's upload speed? The upload speed of most ISP's is much much slower then the more advertised download speed.
It may help to have large images hosted on a photo sharing web site instead of your local server.
Posted: Wed Aug 23, 2017 1:33 pm
by topguy
So its an Apache installation ? With or without Wordpress or other frameworks ?
Like someone else mentions here, you cant really access your external IP from the internal network. Some routers might be smart enough to handle this but most cant. What I do is add the full domain name to the host-file and use the LAN ip. This will make your browser not do DNS lookup but go directly at the server.
https://support.rackspace.com/how-to/mo ... osts-file/
